| wiki3108: Nto640TiOmap2420SdpTrunkReleasenotes | |||||||||||||||||||||||||||||||||||||||
Release Notes for the QNX Neutrino 6.4.0 BSP for Texas Instruments OMAP2420 SDP Trunk#System requirements#Target system#
Host development system#
The interrupt vector table can be found in the buildfile located at src/hardware/startup/boards/omap2420sdp/build
Getting Started#Step 1: Connect your hardware#Connect the serial cable to the serial port of the OMAP2420 SDP board and to the first serial port on the host machine (e.g. ser1 on a Neutrino host).Note:If you have a Neutrino host with a serial mouse, you may have to move the mouse to the second serial port on your host, because some terminal programs require the first serial port. Step 2: Build the BSP#You can build a BSP OS image from the source code or the binary components contained in a BSP package. For instructions about building a BSP OS image, please refer to the chapter Working with a BSP in the Building Embedded Systems manual. Step 3: Transfer the OS image to the target using the ROM monitor#1. On your host machine, start your favorite terminal program with these settings:
Note: The OMAP2420 SDP board from the factory doesn't have a Boot Loader or ROM Monitor installed. You'll need to initially install the U-Boot boot loader onto the board, using Texas Instruments' Code Composer Studio software, and a suitable JTAG emulator, such as the Spectrum Digital XDS510PP. Once you've installed the bootloader, you need to configure it with the TFTP server, etc., which will provide the boot image. At this point, the OMAP2420 SDP board is ready to receive a QNX boot image, in raw format. A raw-format image is simply a binary image, with a header on the beginning, that allows the bootloader to jump to the very beginning of the image (the raw header), where it executes another jump to the first instruction of the image. Later, when the QNX boot image is combined with the native QNX IPL, the boot image will remain in raw format, and the IPL will simply scan past the raw boot header and locate the QNX boot image signature. 2. Start your target. You should see output similar to the following: U-Boot 1.0.0 (Jan 30 2004 - 07:49:02) U-Boot code: 11000000 -> 11015970 BSS: -> 11019674 DRAM Configuration: Bank #0: 10000000 32 MB Micron StrataFlash MT28F128J3 device initialized Flash: 32 MB In: serial Out: serial Err: serial
3. Once these parameters are configured, use the saveenv command to store your changes. Refer to the U-Boot documentation for more information: www.sourceforge.net/projects/u-boot After U-boot is configured, boot the ifs-osk.raw image as follows (we'll assume it's in a directory called /xfer/): tftpboot 10010000 /xfer/ifs-omap2420sdp.raw You should see output similar to the following:
OMAP2420 SDP# tftpboot 10010000
TFTP from server 10.0.0.5; our IP address is 10.1.0.28; sending through
gateway 10.0.0.5
Filename '/xfer/ifs-omap2420sdp.raw'.
Load address: 0x80010000
done
Bytes transferred = 799464 (c32e8 hex)
OMAP2420 SDP #
go 80010000 You should see output similar to the following: CPU0: Dcache: 1024x32 WB CPU0: Icache: 1024x32 CPU0: VFP 410120b2 CPU0: 4107b362: arm1136 rev 2 300MHz System page at phys:802db000 user:fc404000 kern:fc404000 Starting next program at vfe03c03c cpu_startnext: cpu0 -> fe03c03c Welcome to QNX Neutrino Trunk on the Texas Instruments OMAP2420SDP Board # # 4. Once you've established the U-Boot commands to download the image and boot the board, you can also configure U-Boot to save these commands; type the following at the OMAP5912 OSK prompt: setenv bootcmd tftpboot 80010000 /xfer/ifs-omap2420sdp.raw\; go 80010000 saveenv To boot the board, enter: bootd Step 4: Flashing the IPL on to the target#Step 4A: Creat the IPL image#
Note:
For further information on how to use the TI CSST tools to program the IPL/IFS images to NAND, please refer to "CSST Quick Start Guide for SDP242x" and "OSTBoot Version 1.7 Release OMAP242x Release Notes".
Run the mkflashimage script, inside the /images directory of the BSP. The output file from this script is a combined IPL/OS image called ipl-ifs-omap2420sdp.bin. You'll download this file to the board's memory using the bootloader, and then burn the image into the board's flash. The IPL is padded to 64K.
The following steps describes how to generate the ipl-ifs-omap2420sdp.bin:
#!/bin/sh
# script to build a binary IPL and boot image for the OMAP 2420 SDP board
set -v
# Convert IPL header into Binary format
${QNX_HOST}/usr/bin/ntoarm-objcopy --input-format=elf32-littlearm --output-format=binary ../src/hardware/ipl/boards/omap2420sdp/arm/le/boot_header.o ./tmp-boot-header.bin
# Convert IPL into Binary format
${QNX_HOST}/usr/bin/ntoarm-objcopy --input-format=elf32-littlearm --output-format=binary ../install/armle/boot/sys/ipl-omap2420sdp ./tmp-ipl-omap2420sdp.bin
# Cat boot header and ipl together
cat ./tmp-boot-header.bin ./tmp-ipl-omap2420sdp.bin > ./tmp-header-ipl-omap2420sdp.bin
# Pad Binary IPL to 64K image
mkrec -s64k -ffull -r ./tmp-header-ipl-omap2420sdp.bin > ./ipl-omap2420sdp.bin
# Combine the IPL with the OS Image
cat ./ipl-omap2420sdp.bin ./ifs-omap2420sdp.bin > ./ipl-ifs-omap2420sdp.bin
# clean up temporary files
rm -f tmp-boot-header.bin tmp-ipl-omap2420sdp.bin tmp-header-ipl-omap2420sdp.bin ipl-omap2420sdp.bin
echo "done!!!!!!!"
Step 4B: Flashing an IPL image using the TI OSTBOOT utility#The following procedure describes how to erase the first 4MB and flash an IPL image using the TI OSTBOOT utility. The TI OMAP2420 OSTBOOT utility should have been successfully installed on the host. These commands assume that the OS image, ifs-omap2420sdp.bin, is less than (4M - 64K) bytes. The working directory is C:/omap2420sdp/. 1. Connect a RS232 null modem cable between the host and the RS232 connector (J400) on the OMAP2420 SDP base board. 2. Set Switch SW1 to SW5 according to the 2nd table on page 10 of "CSST Quick Start Guide for SDP242x" 3. Start the download process from the Windows host with the TI OMAP242x OSTBOOT utility. Using CSST_OMAP242x_V1.7, Click "download" in the "target" pane on the left side. Select the "Erase" tab in the "SDP2420-GP" pane on the right, and erase the entire NAND flash. Select the "Download" tab; click "Add File" and select ipl-ifs- omap2420sdp.bin. Click the "Download" button to start the download process. 4. Reset the target board when CSST_OMAP242x_V1.2 prompts to do so. 5. After the download process finishes, connect the RS232 cable to J9 on the daughter board. 6. Set switch SW1 to SW5 according to the 3rd table on page 14 of the "CSST Quick Start Guide for SDP242x". 7. Reset the board. Step 5: Download an OS image using the IPL and sendnto#Due to issues with TI OSTBOOT utility, an OS image burnt to NAND flash with OSTBOOT doesn’t work. Here is the procedure to download an OS image to memory using sendnto. 1. Start the QNX Momentics IDE on the host. 2. Open a terminal server window. See the IDE documentation for details. 3. Connect the RS232 null modem cable between the host and J9 on the OMAP2420sdp board. 4. Start the target, assuming an IPL has been successfully flashed to the board following the steps in section IV above. 5. When you see the following message: QNX Neutrino Initial Program Loader for Texas Instruments OMAP2420SDP Commands: Press 'D' for serial download, using the 'sendnto' utility Press 'N' to boot an OS image in NAND flash Type D to start download process on the target end. 6. In the terminal server window, click the "send file" button in the upper left corner. A popup window will open. Type or browse the correct image file name in the "Filename" box and sendto as the proctocol. Click OK to start the download on the host side. or using the QNX 'sendnto' utility: sendnto -d/dev/ser1 -b115200 ./ifs-omap2420sdp.bin to download image 7. After the download process finishes, the target will start the OS automatically. You should see output similar to the following: send image now... download OK... Found image @ 0x81000000 Jumping to startup @ 0x80011A60 CPU0: Dcache: 1024x32 WB CPU0: Icache: 1024x32 CPU0: VFP 410120b2 CPU0: 4107b362: arm1136 rev 2 300MHz System page at phys:802db000 user:fc404000 kern:fc404000 Starting next program at vfe03c03c cpu_startnext: cpu0 -> fe03c03c Welcome to QNX Neutrino Trunk on the Texas Instruments OMAP2420SDP Board #
Known Issues for this BSP#
