wiki3000: BinaryPackages (Version 13)
Binary Packages#
Set up your environment (the following assumes the default prefix of /usr/pkg)#
  • Add /usr/pkg/bin:/usr/pkg/sbin to your PATH environmental variable. For example, do the following once:
# echo 'export PATH=${PATH}:/usr/pkg/bin:/usr/pkg/sbin' >> ~/.profile
<log out>
<log back in>
# echo ${PATH}
  • Add /usr/pkg/lib to your CS_LIBPATH. For example, I have the following in my /etc/rc,d/rc.local
setconf CS_LIBPATH $(getconf CS_LIBPATH):/usr/pkg/lib
  • Make a /var/tmp directory (pkg_add currently looks for this)
# mkdir -p /var/tmp
Where to find them#
  • Binary packages for QNX are currently hosted on ftp.NetBSD.org. under ftp://ftp.NetBSD.org/pub/pkgsrc/packages/QNX.
    • The layout is pub/pkgsrc/packages/QNX/<arch>/<vers>
    • Bootstrap archives can be found under:
  • Untar bootstrap.tar.gz under the root directory (/).
  • Packages can then be added as follows:
# export PKG_PATH=ftp://ftp.NetBSD.org/pub/pkgsrc/packages/QNX/<arch>/<vers>/All
# pkg_add -v <package>
6.3.2 packages.#
Text 6.5.0_bootstrap.tar.gz [BinaryPackages/6.5.0_bootstrap.tar.gz]
