| wiki2961: Nto640TiOmap5912OskTrunkReleasenotes (Version 2) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Release Notes for the QNX Neutrino 6.4.0 BSP for Texas Instruments OMAP5912 OSK Trunk#System requirements#Target system#
Host development system#
The interrupt vector table can be found in the buildfile located at src/hardware/startup/boards/osk/build
Getting Started#Step 1: Connect your hardware#Connect the serial cable to the serial port of the OMAP 5912 board and to the first serial port on the host machine (e.g. ser1 on a Neutrino host).Note:If you have a Neutrino host with a serial mouse, you may have to move the mouse to the second serial port on your host, because some terminal programs require the first serial port. Step 2: Build the BSP#You can build a BSP OS image from the source code or the binary components contained in a BSP package. For instructions about building a BSP OS image, please refer to the chapter Working with a BSP in the Building Embedded Systems manual. Step 3: Transfer the OS image to the target using the ROM monitor#1. On your host machine, start your favorite terminal program with these settings:
Note: The OSK board from the factory doesn't have a Boot Loader or ROM Monitor installed. You'll need to initially install the U-Boot boot loader onto the board, using Texas Instruments' Code Composer Studio software, and a suitable JTAG emulator, such as the Spectrum Digital XDS510PP. The bootloader image is provided with the software that comes with the OSK, and the instructions to install it are described in the OSK_quickstart.doc MS Word document, also provided with the OSK software. Once you've installed the bootloader, you need to configure it with the TFTP server, etc., which will provide the boot image. At this point, the OSK board is ready to receive a QNX boot image, in raw format. A raw-format image is simply a binary image, with a header on the beginning, that allows the bootloader to jump to the very beginning of the image (the raw header), where it executes another jump to the first instruction of the image. Later, when the QNX boot image is combined with the native QNX IPL, the boot image will remain in raw format, and the IPL will simply scan past the raw boot header and locate the QNX boot image signature. 2. Start your target. You should see output similar to the following: U-Boot 1.0.0 (Jan 30 2004 - 07:49:02) U-Boot code: 11000000 -> 11015970 BSS: -> 11019674 DRAM Configuration: Bank #0: 10000000 32 MB Micron StrataFlash MT28F128J3 device initialized Flash: 32 MB In: serial Out: serial Err: serial
3. Once these parameters are configured, use the saveenv command to store your changes. Refer to the U-Boot documentation for more information: www.sourceforge.net/projects/u-boot After U-boot is configured, boot the ifs-osk.raw image as follows (we'll assume it's in a directory called /xfer/): tftpboot 10010000 /xfer/ifs-osk59xx.raw You should see output similar to the following:
OMAP5912 OSK # tftpboot 10010000
TFTP from server 10.0.0.5; our IP address is 10.1.0.28; sending through
gateway 10.0.0.5
Filename '/xfer/ifs-osk59xx.raw'.
Load address: 0x10010000
done
Bytes transferred = 799464 (c32e8 hex)
OMAP5912 OSK #
go 10010000 You should see output similar to the following: ## Starting application at 0x10010000 ... Dcache: 256x32 WB Icache: 512x32 arm926 rev 3 192MHz System page at phys:101bd000 user:fc404000 kern:fc404000 Starting next program at vfe01c72c Welcome to QNX Neutrino on the Texas Instruments OMAP Starter Kit (OSK) Board # # 4. Once you've established the U-Boot commands to download the image and boot the board, you can also configure U-Boot to save these commands; type the following at the OMAP5912 OSK prompt: setenv bootcmd tftpboot 10010000 /xfer/ifs-osk.raw\; go 10010000 saveenv To boot the board, enter: bootd Step 4: Replace the U-Boot bootloader with a native QNX IPL and OS image in flash#At some point, you may wish to replace the U-Boot bootloader with the native QNX IPL code. This may be desirable once you've tweaked the OS image exactly the way you want it, and you want the board to boot the image automatically, immediately on power up. 1. Modify your buildfile to generate a binary image. 2. Run the mkflashimage script, inside the /images directory of the BSP. The output file from this script is a combined IPL/OS image called ipl-ifs-osk59xx.bin. You'll download this file to the board's memory using the bootloader, and then burn the image into the board's flash. The IPL is padded to 16K because if the IPL is scanning for an OS image in flash, it begins scanning at offset 16K in the flash. The mkflashimage script:
#!/bin/sh
# script to build a binary IPL and boot image for the OMAP 5912 OSK board
set -v
#convert IPL into an S-Record
${QNX_HOST}/usr/bin/ntoarm-objcopy -Osrec ../install/armle/boot/sys/ipl-osk ipl-tmp-osk.srec
#convert S-Record IPL to binary
${QNX_HOST}/usr/bin/ntoarm-objcopy -Obinary ipl-tmp-osk.srec ipl.tmp
mkrec -r -ffull -s16k ipl.tmp > ipl-tmp-osk.bin
#generate binary boot image
make
#combine ipl with boot image
cat ipl-tmp-osk.bin ifs-osk59xx.raw > ipl-ifs-osk59xx.bin
echo "done!!!!!!!"
Instead of starting the image, we'll now transfer the bootable flash image (IPL/OS) to the board. The bootloader can convert to binary format the last image it downloaded
and then write it to flash.
4. If it's not already started, start the network driver as follows, substituting your own IP address for x.x.x.x: io-pkt-v4 -dsmc9000 ioport=0x04800000,irq=200 ifconfig en0:x.x.x.x 5. Start fs-nfs2, establishing an NFS connection to the host machine where your ipl_ifs-osk.bin image resides: fs-nfs2 x.x.x.x:/mount_dir /nfs Note: Ensure that you can "see" the ipl-ifs-osk59xx.bin file over the NFS connection, because in the next step, the bootloader will be erased. If the programming of the combined IPL and OS image fails or is interrupted, it will be necessary to reprogram U-Boot with Code Composer Studio. 6. Start the flash filesystem driver and erase the first 1MB of flash as follows (erase a larger area if the size of your combined image exceeds 1MB): devf-generic -s0,32M flashctl -p/dev/fs0 -l1M -ev cp -V /nfs/ipl-ifs-osk59xx.bin /dev/fs0 When the copy is complete, you can reboot; it should now boot from the native QNX IPL. You should see output as follows: QNX Neutrino Initial Program Loader for Texas Instruments OSK Commands: Press 'S' for serial download, using the 'sendnto' utility Press 'F' to boot an OS image in flash You'll see output similar to the following: found image, calling image setup... image_setup OK, calling image start... Dcache: 256x32 WB Icache: 512x32 arm926 rev 3 192MHz System page at phys:101bd000 user:fc404000 kern:fc404000 Starting next program at vfe01c72c Welcome to QNX Neutrino on the Texas Instruments OMAP Starter Kit (OSK) Board # To do this, modify the <main.c> file of the IPL source, located under: $BSP_PATH/osk/src/hardware/ipl/boards/osk/ You can now test the OS, simply by executing any shell builtin command or any command residing within the OS image (e.g. ls). Creating a flash partition#1. Enter the following command to start the flash filesystem driver: devf-generic -s0,32M 2. Unlock the entire flash, except for the first megabyte: flashctl -p/dev/fs0 -o1M -l31M -U 3. Erase the flash, except for the first megabyte: flashctl -p/dev/fs0 -o1M -l31M -ve 4. Format the partition: flashctl -p/dev/fs0p0 -o1M -l31M -vf 5. Slay, then restart the driver: slay devf-generic devf-generic -s0,32M & You should now have a /fs0p1 directory automounted.
Some of the drivers are commented out in the default buildfile. To use the drivers in the target hardware, you'll need to uncomment them in your buildfile, rebuild the image, and load the image into the board. USB, I2C and Audio have additional details: The I2C driver needs to be running before you can use the USB driver and the Audio driver. To start the USB or audio, you'll need to execute the commands in the order indicated above. Audio components#The audio system on the OMAP board consists of hardware and software components. The hardware components are:
An audio application uses the DSP to transfer audio data to the codec. The software components are:
Note: In order to run the audio driver, you'll need to use the DSP manager to download a DSP image to the OSK board. This DSP image is only available from Texas Instruments. The DSP image must match the Link library version 1.11 provided with this BSP. Please contact your Texas Instruments sales team to obtain it.
Known Issues for this BSP#
To test or evaluate Photon on your target before embedding it you could make the Photon environment accessible to the target by simply mounting your host environment into the target. You'll need
to use an NFS or CIFS client on the target depending on the type of server running on your host platform. This example shows how to create a basic Photon configuration using an NFS client.
1. Uncomment the following sections from the build file: network, usb and graphics
2. Add the following at the end of the network section:
fs-nfs3 10.0.0.1:$QNX_TARGET/cpu/ /
10.0.0.1:$QNX_TARGET/etc /etc
10.0.0.1:$QNX_TARGET/usr/photon /usr/photon &
waitfor /usr/bin
waitfor /usr/photon
waitfor /etc
Where 10.0.0.1 is the server IP address
Note: The first three lines of the fs-nfs command comprise one command.
3. You can now run the Photon drivers.
To run the graphics driver:
/usr/photon/bin/Photon &
waitfor /dev/photon
/usr/photon/bin/io-graphics -d...
(See the "Devices supported" chapter in the BSP documentation for details on the graphics driver options).
To use a usb mouse and keyboard:
/sbin/io-hid -dusb
/usr/photon/bin/devi-hid kbd mouse &
The IPL sets the frequency to 192MHz.
You can check for permanent ARP entries by running the arp -an command and examining the output. The only permanent entries listed should be for the IP addresses assigned to your host's interfaces;
there shouldn't be any permanent, incomplete entries. If you find a permanent entry that isn't for the IP address of an interface on your host, and you didn't explicitly create a permanent entry, then you
could be encountering this problem. (Ref# 21395)
Workaround: In the buildfile for your OS image, delay the start of the TCP/IP stack or the first TCP/IP application by at least one second, by using the sleep command (e.g. sleep 1) or some other delay mechanism.
