Freescale MPC8313E RDB Board Support Package#
This BSP supports the Freescale MPC8313E RDB board.
Releases#
QNX Neutrino 6.4.0#
QNX Neutrino 6.3.2#
Features#
| Feature | Planned Availability | Format | Notes |
| Startup | Completed | SRC | . |
| Serial | Completed | SRC | . |
| Ethernet | Completed | SRC | for 6.3.2 BSP: eTSEC Ethernet controller in TSEC compatibility mode (in-net) |
| Ethernet | Completed | BIN | for 6.4.0 BSP: eTSEC Ethernet controller in TSEC compatibility mode (io-pkt) |
| I2C | Completed | SRC | I2C controller |
| SPI | Completed | SRC | . |
| NAND | Completed | SRC | K9F5608UOD (32 MB) NAND Flash |
| NOR | Completed | SRC | EN29LV640 (8 MB) NOR Flash |
| PCI | Completed | SRC | . |
| USB | Completed | BIN | . |
Some of these drivers are commented out in the default buildfile. To use the drivers in the target hardware, you'll need to uncomment them in your buildfile, rebuild the image, and load the image into the board.
QNX Neutrino 6.4.0 Change History#
Trunk#
- Created from QNX Neutrino 6.3.2 BSP for Freescale MPC8313E RDB 1.0.0
- Built using the latest 6.4.0 toolchain
1.0.0#
QNX Neutrino 6.3.2 Change History#
1.0.0#
- Initial release under Apache II and QDL
- Includes:
- Ethernet driver
- I2C driver
- NAND flash driver
- NOR flash driver
- PCI driver
- Serial driver
- SPI driver
- Startup
- USB
Search Keywords: 8313, mpc8313, rdb, Freescale, MPC8313, RDB
