| wiki2901: Source_XML_Reference (Version 1) | |||||||||||||||||||||||||||||||||||||||||||||||||
source.xml Reference#The IDE uses the source.xml to gather and display information about a BSP. Here's an example for the Freescale Sandpoint board:
<!-- Unless otherwise specified, values/attributes are free-form strings -->
<!-- type is currently either BSP or SourceOnly -->
<sourcePackage type="BSP" id="bsp-freescale-sandpoint">
<title>Freescale Sandpoint</title>
<release>1.0.1</release>
<description>
This package contains the source and build files for targeting QNX Neutrino on the
Freescale Sandpoint reference board. This includes support for the MPC750, MPC755,
MPC7400, MPC7410, MPC7450, MPC7447A, MPC7455, MPC8240, and MPC8245.
</description>
<vendor>QNX Software Systems</vendor>
<qnxTargetVersion>6.3.0SP1</qnxTargetVersion>
<qnxTargetCPU variant="ppcbe">PowerPC</qnxTargetCPU>
<!-- type is currently only import, will be extended in the future. -->
<bsp type="import">
<import id="sandpoint-flash">images/sandpoint-flash.build</import>
<import id="sandpoint">src/hardware/startup/boards/sandpoint/build</import>
<imageCombine iplEnable="true" iplFileName="ipl-sandpoint" iplPadSize="0x2000" finalEnable="true" finalFormat="srec" />
</bsp>
</sourcePackage>
Element sourcePackage#<sourcePackage type="package-type" id="package-id"> This is the main element in the setup.xml file. It should occur only once.
Board support packages should have the BSP type.
Element title#<title> bsp title </title> This element specifies the readable package title. Element release#<release> release number </release> This element specifies the package release. BSP packages are released against major versions of the QNX SDP starting at 1.0.0. Element description#<description> long description </description> This element contains the long description of the BSP that is presented to the user by the IDE during import. Element vendor#<vendor> pretty vendor string </vendor> This element specifies the vendor responsible for the package. Official QNX packages have QNX Software Systems in this field. Element qnxTargetVersion#<qnxTargetVersion> QNX SDP Version </qnxTargetVersion> This element specifies the version of the QNX Software Development Platform that this BSP targets. BSP targeting QNX SDP 6.4.0 should have 6.4.0 here. Element qnxTargetCPU#<qnxTargetCPU variant="variant"> pretty variant </qnxTargetCPU> This element specifies the variant of the target CPU, typically x86, PPC, ARM, SH
Element bsp#<bsp type="import"> ... </bsp> This element provides the default configuration to the QNX System Builder. See the Building OS and Flash Images section in the QNX Momentics Integrated Development Environment - IDE 4.5 User's Guide for an overview.
Element import#<import id="build file id"> path to build file </import> This element specifies a path to build file, which will be used as the basis to generate an image. Multiple build files can be referenced by multiple inclusions.
Element imageCombine#<imageCombine iplEnable="true" iplFileName="ipl filename" iplPadSize="pad size" finalEnable="true" finalFormat="format" /> This element specifies the manner in which mkrec and mkimage will be invoked. It should be specified only once.
