| wiki2812: Common_gcc_errors (Version 1) |
Specific Issues moving from GCC 2.95.3 to GCC 4.x #These are the most common errors that emerge with gcc 4. error: lvalue required as left operand of assignment#Older gcc versions contained an extension called cast-as-lvalue which would allow assignment of a variable as a different type as in: int foo; float bar; (float)foo = bar; This extension is deprecated because it's dangerous. The correct way get behaviour like above is to use a union. If it's pointers being assigned, just cast the right side to the type of the left, instead of the other way around. Note that accessing a member of a cast struct is still valid. For example: ((some_struct *)(myStruct))->member = foo; // this is valid (int)((some_struct *)(myStruct))->member = foo; // this will produce an error error: label at end of compound statement#This one is very simple, and usually occurs with a switch statement like:
switch (foo) {
case 1:
// do stuff
break;
default:
Simply remove "default:" or add "break;" after it, and gcc will be happy. file.c:456: error: conflicting types for 'some_function'#file.c:123: error: previous implicit declaration of 'some_function' was here#or file.c:49: error: expected '=', ',', ';', 'asm' or 'attribute' before 'some_function' #Solution: Didn't your programming teacher tell you to always make function prototypes? He/she had good reason. It's also best to have them at the top, global space of the file, not in weird places. Yes, I have seen a function declared within another function, just before it gets called. Try to avoid that. |
