| wiki2761: Nto640_centrality_atlasii_evb_trunk_releasenotes (Version 9) | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Release Notes of the QNX 6.4.0 BSP for Centrality Atlas II EVB Trunk#System requirements#Target system#
Host development system#
Note: The initial board configuration requires a Microsoft Windows host.
System Layout#The table below depicts the memory layout for the image and for the on-board flash.
Getting Started#Step 1: Connect the hardware#Connect the Centrality Atlas II board's power supply as per the instructions provided with the hardware.Connect the straight-through serial cable between the USP0 port (P7) on the Atlas II. Connect the supplied USB cable to the P11 connector (USB client) on the centrality Atlas II board. Connect the other end of the USB cable to a free USB port on a Windows PC. Step 2: Generate the OS image and IPL#For instructions about building a BSP OS image, please refer to the chapter Working with a BSP in the Building Embedded Systems manual. The IPL binary needs to be padded to 16 KB before transferring it to the board via NBoot. This step is done automatically when generating the IPL binary from the source code on the command line. Use the notarm-objcopy and mkrec to pad the IPL binary to 16 KB:
rm -f ipl-atlasii.bin
#convert IPL into an S-record
${QNX_HOST}/usr/bin/ntoarm-objcopy -Osrec ipl-atlasii ipl-tmp-atlasii.srec
#convert S-Record IPL to binary
${QNX_HOST}/usr/bin/ntoarm-objcopy -Obinary ipl-tmp-atlasii.srec ipl.tmp
mkrec -r -ffull -s16k ipl.tmp > ipl-atlasii.bin
#cleaning up temporary files
rm -f *tmp*
This step is necessary only when transferring the pre-built IPL via NBoot or the IDE. Step 3: Prepare to flash the IPL #The procedure in Step 4 will replace the NBoot loader with a QNX Initial Program Loader (IPL), which can then be used to load a QNX OS image serially or from the flash. To perform this procedure, you will need a Microsoft Windows utility called AtlasMgr2.exe, for NBoot v2.01, or AltasMgr5.exe for NBoot v5.0), both available from Centrality. You will also need to install a USB device driver, available from Centrality, on the Windows host for the Atlas II board.
Note: The Centrality tools are usually provided with the Centrality Atlas II board.
On your host machine, start your terminal program with these settings:
The Atlas II board has a two-stage boot process. The first loader to run is called NBoot, which will present the user with a menu of further boot and configuration options. The second loader called EBoot won't be used. Transfer the binary IPL to the MS Windows host that is connected to the Atlas II board via the USB link. The binary IPL file is called ipl-atlasii.bin. If you built the BSP on the command line the IPL will be located at images/ipl-atlasii.bin. See Step 2: Generate the OS image and IPL for more details. Step 4: Flash the IPL#Before transferring the OS image to the board, you'll need to program the IPL to the flash. The Centrality Altas II board is equipped with on-board NAND flash (either on the mainboard (MB) or on the CPU module (CM)) and a SmartMedia card reader. It is possible to boot from any of these flash devices. Therefore you can transfer the IPL to either one of these boot devices. Refer to Step 4A to use the on-board NAND flash. Refer to Step 4B to use the SmartMedia. The IPL will be flashed on top of the ROM monitor NBoot. Once the NBoot is replaced by the QNX IPL, it will not be possible to reflash NBoot back into the board. However it will still be possible to update the IPL by using the I option from the IPL menu. See Step 3.2: Update the IPL for more details. Step 4A: Transfer the IPL to the on-board NAND flash#In this step you will write the IPL to the on-board NAND flash.
Note: If you wish to keep a copy of the ROM monitor on the board, you can flash it into the ~Smartmedia card before copying the IPL to the on-board flash. You can follow the steps documented in Step 4B: Program the IPL as a guideline. Replace any reference to IPL with ROM monitor in order to program the ROM monitor into the ~Smartmedia card.
There are two banks of DIP switches in the lower right corner of the Atlas II board, SW1 and SW2. Each bank has 4 DIP switches. Place all eight DIP switches in the OFF position. This puts the board into Normal Operation Mode, and selects NAND_CS0 (i.e. on-board NAND flash) as the boot device. Apply power to the Centrality Atlas II board. On the serial console, you should the following NBoot output when using NBoot v2.01:
WinCE NAND Boot v2.01
Jun 27 2005 12:13:09
TOC: 0x00000001
EBOOT: 0x00000002
NANDXIP: 0x00000000
DM: 0x00000000
Image start: 0x0000000C
Image Blocks: 0x00000000
g_dwIoClock: 0x02FAF080
1): Launch NK
2): Launch EBOOT
3): Launch DM
4): Enter USB Mode to Update Bootloader
6): Erase flash except NBOOT
7): Show NBOOT Menu: ENABLED
9): FCE2/3 Setting
0): Clock set
Select:
If the above NBoot menu isn't displayed, press the the lower right button on below the LCD panel and simultaneously press the reset button. The NBoot menu should then be visible. Select the option #7 in order to permanently display the NBoot menu at boot time. Then perform the following:
You should then see the following IPL output (or similar):
QNX Neutrino Initial Program Loader for Centrality ATLAS-II board Commands:
Press 'D' for serial download, using the 'sendnto' utility
Press 'F' to Boot an OS image from NAND flash
Press 'U' to Copy an OS image to NAND flash
Press 'I' to Update the IPL
Press 'S' to Select Clock
Step 4B: Transfer the IPL to the ~Smartmedia NAND flash (Alternative to Step 4A)#The IPL will be flashed on top of the ROM monitor NBoot. Once the NBoot is replaced by the QNX IPL, it will not be possible to reflash NBoot back into the board. However it will still be possible to update the IPL by using the I option from the IPL menu. See Step 4.2: Update the IPL for more details.
Note: If you wish to keep a copy of the ROM monitor on the board, you can flash it into the on-board NAND flash before copying the IPL to the SM card. You can follow the steps documented in Step 4A: Program the IPL as a guideline. Replace any reference to IPL with ROM monitor in order to program the ROM monitor into the on-board NAND flash.
There are two banks of DIP switches in the lower right corner of the Atlas II board, SW1 and SW2. Each bank has 4 DIP switches. Place all eight DIP switches in the OFF position. This puts the board into Normal Operation Mode, and selects NAND_CS0 (i.e. on-board NAND flash) as the boot device. Insert the SmartMedia card in its slot. Apply power to the Centrality Atlas II board. On the serial console, you should the following NBoot output when using the version 2.01:
TOC: 0x00000001
EBOOT: 0x00000002
NANDXIP: 0x00000000
DM: 0x00000000
1): Launch NK
2): Launch EBOOT
3): Launch DM
9): FCE2/3 Setting
0): Clock set
Select:
If the above NBoot menu isn't displayed, press the the lower right button on below the LCD panel and simultaneously press the reset button. The NBoot menu should then be visible. Select the option #7 in order to permanently display the NBoot menu at boot time. Select the option FCE2/3 Setting then select the option #1 from the following sub-menu to select SM (SmartMedia).
0): FCE2 -> Empty
1): FCE3 -> SM
2): Return
Select:
Select the option #2 of the sub-menu to return to the main NBoot menu. Then perform the following:
Commands:
Step 5: Update the IPL#Once the IPL is running on the board, you can update the IPL with a new version. Copy the IPL to the host system that is connected to the Atlas II board via a serial link. The IPL file should be called ipl-atlasii (ELF format only for command line users). src/hardware/ipl/boards/atlasii/arm/le or images/ipl-atlasii. For IDE users, both binary (i.e. ipl-atlasii.bin) or ELF formats can be used. From the IPL commands menu, select option I to download and to program the IPL into the flash. If teh IPL is located in the NAND flash, you should see the following sub-menu:
Booting from on-board NAND flash
Press "1" to update IPL on SM card
Press any other key to update IPL on on-board NAND flash
If the IPL is located on the SmartMedia card, you should see the following sub-menu:
Booting from SM card
Press "1" to update IPL on MB NAND flash (CM NAND flash update not supported)
Press any other key to update IPL on SM card
Press any key other than 1 to update the IPL in place. The 1 option will update the alternate IPL. After making a selection the following will be displayed,
send the IPL now...
Note:
Updating the IPL on the flash located on the CPU module, when booting from the SM card, isn't supported. Then use the QNX sendnto utility to transfer the IPL from the host to the Centrality Atlas II board. For instance, from the command line, run sendnto as follows: sendnto -d <host-serial-port> ipl-atlasii Once the IPL is successfully downloaded and programmed into the flash you should see the following message:
Update IPL OK
Reset the board. You should then see the new IPL output. For instance:
Commands:
Step 6: Transfer the OS image to the board#Once the IPL is running on the board, use the following steps to transfer the OS image to the board. You can either transfer the OS image into RAM and execute it from RAM or transfer it to flash then boot from flash. Step 6.1: Transfer the OS image to RAM#Locate the QNX OS image (ifs-atlasii.bin) generated in Step 2: Generate the OS image and IPL. Select the IPL option D to download the OS image serially to the board. Use the QNX sendnto utility to transfer the OS image from the host to the Centrality Atlas II board. For instance: sendnto -d <host-serial-port> ifs-atlasii.bin Once the transfer is completed, the OS image will be executed and QNX Neutrino will boot on the board. You should also see the following welcome message on your terminal screen:
Welcome to QNX Neutrino 6.x on the Centrality Communications Atlas II Board
Step 6.2: Transfer the OS image and program it into the NAND flash (optional)#Once the IPL is running on the board, use the following steps to transfer the OS image to the board and program it to the flash.
sendnto -d<host-serial-port> ifs-atlasii.bin.
Change the clock settings (optional)#Once the IPL is running on the board, you can use the following steps to change the clock settings for the Atlas II board. Select the IPL option S to change the clock settings. You should see the following output:
a) SDR_276_184_92_46
b) SDR_264_176_88_44
c) SDR_252_168_84_42
d) SDR_240_160_80_40
e) SDR_228_152_76_38
f) SDR_216_144_72_36
g) SDR_276_184_92_92
h) SDR_264_176_88_88
i) SDR_252_168_84_84
j) SDR_240_160_80_80
k) SDR_228_152_76_76
l) SDR_216_144_72_72
1) return:
The IPL uses the following setting by default:
Some of the drivers are commented out in the default buildfile. To use the drivers in the target hardware, you'll need to uncomment them in your buildfile, rebuild the image, and load the image into the board. ETFS NAND flash#Command to run the ETFS NAND flash driver on a Samsung K9K1G08U0M on-board flash part (128MB): fs-etfs-atlasii512 -r65536 -m /fs/etfs Where -r <cluster-number> is the number of clusters (a cluster contains 2 pages of 512B) to reserve for the IPL, the OS image and potential bad blocks skipped when the IPL and the OS image are copied to the flash. You should then see /dev/etfs1 and /dev/etfs2 partitions. The /dev/etfs1 partition contains the IPL and the OS image so make sure to not erase it. Command to run the ETFS NAND flash driver on a Samsung K9F1208U0B on-board flash part (64MB): You should now see the mount point /fs/etfs/ which can be used to copy files to. The above commands are to be executed on the boot device (which could be either the on-board NAND or the SM card). It is possible to run the ETFS driver on the other flash part (which wasn't used for booting) using the following options: Make sure that the SM card is inserted before starting the driver in order to detect it. The ETFS driver does not support Plug-and-Play. SD card#Command to run the SD card block driver on a SD flash card (4GB maximum): If the card has been formatted with a QNX filesystem (i.e. type 77 for instance), you can mount the device using the follow command: Audio#There are two blocks of DIP switches on the mainboard that control connections to the AC97 codec chip: S4 and S10. You may need to remove the LCD panel (if the 7" panel is installed) to gain access to these switches. All of these switches need to be set in the "ON" position for the AC97 driver to work. USB#Due to the hardware design, both the USB host and USB client ports share the same lines. They cannot both be plugged in at the same time.
Known Issues#
