Freescale i.MX27 ADS Board Support Package#
This BSP supports the Freescale i.MX27 ADS board.
Releases#
QNX Neutrino 6.4.0#
QNX Neutrino 6.3.2#
Features#
| Feature | Planned Availability | Format | Notes |
| Ethernet | Completed | SRC | 10 BaseT Ethernet controller -- Crystal LAN CS8900A |
| FEC | Completed | SRC | 10/100Mbps Fast Ethernet Controller (FEC): AMD Am79C874VD |
| I2C | Completed | SRC | MX31 I2C manager. Master library also included in BIN form |
| NOR | Completed | SRC | AMD Flash: 32 MB flash (S71WS256NDO) |
| NAND | Completed | SRC | Saumsung NAND Flash: 128 MB NAND flash (K9K1G08U0B-JIB0) |
| Serial | Completed | SRC | On-board UART: MX27 UART |
| Startup | Completed | SRC | . |
| USB Host | Completed | BIN | USB host1 FS & USB host2 HS |
| USB Device | Completed | BIN | USB OTG_FS device |
| USB Mass Storage | Completed | BIN | . |
Some of these drivers are commented out in the default buildfile. To use the drivers in the target hardware, you'll need to uncomment them in your buildfile, rebuild the image, and load the image into the board.
QNX Neutrino 6.4.0 Change History#
Trunk#
- Created from QNX Neutrino 6.3.2 BSP for Freescale i.MX27 ADS 1.0.0
- Built using the latest 6.4.0 toolchain
- The serial driver supports the software flow control
QNX Neutrino 6.3.2 Change History#
1.0.0#
- Initial release under Apache II
- Includes:
- Startup
- Serial
- Ethernet
- FEC
- NAND
- NOR
- I2C
- USB Host
- USB device
- USB Mass Storage
Search Keywords: mx, i.mx, .mx27, ads, Freescale, MX, i.MX, .MX27, ADS
