Freescale i.MX21 ADS Board Support Package#
This BSP supports the Freescale i.MX21 ADS board.
Releases#
QNX Neutrino 6.4.0#
QNX Neutrino 6.3.2#
| Date | Version | Prerequisites | Installation Notes | Release Notes | License(s) | Support | Provider | Download |
| 2007-12-03 | 1.0.0 | QNX Momentics 6.3.x SP3 or later + AGTDK + latest Character DDK | 6.3.2 Generic Notes | included in archive | QDL and Apache II | Experimental | QNX | Project Downloads |
Features#
| Feature | Planned Availability | Format | Notes |
| Ethernet | Completed | SRC | 10 BaseT Ethernet controller: Crystal LAN CS8900A |
| IPL | Completed | SRC | . |
| I2C | Completed | SRC | MX21 I2C manager. Master library also included in BIN form |
| Graphic | Completed | SRC | On-board graphics controller driver for Graphic Framework (GF) |
| NOR | Completed | SRC | AMD Flash: 32MB burst flash (AM29BDS128) |
| NAND | Completed | SRC | Saumsung NAND Flash: 64MB NAND flash (K9K1208Q0C) |
| Serial | Completed | SRC | On-board UART: MX21 UART |
| SPI | Completed | SRC | MX21 SPI master controller |
| Startup | Completed | SRC | . |
| USB Host | Completed | BIN | . |
Some of these drivers are commented out in the default buildfile. To use the drivers in the target hardware, you'll need to uncomment them in your buildfile, rebuild the image, and load the image into the board.
QNX Neutrino 6.4.0 Change History#
Trunk#
- Created from QNX Neutrino 6.3.2 BSP for Freescale i.MX21 ADS 1.0.0
- Built using the latest 6.4.0 toolchain
- The serial driver supports the software flow control
QNX Neutrino 6.3.2 Change History#
1.0.0#
- Initial release under Apache II
- Includes:
- IPL
- Graphics
- I2C
- Serial
- SPI
- Startup
- USB Host
- NAND
- NOR
- Ethernet
Search Keywords: mx, i.mx, .mx21, ads, Freescale, MX, i.MX, .MX21, ADS
