wiki1523: PackageStatus_devel (Version 1)
  • devel/SDL-intro-en
  • devel/SDL-intro-ko
  • devel/acme
  • devel/adocman
  • devel/apr0
  • devel/arena
  • devel/argtable
  • devel/asm2html
  • devel/astyle
  • devel/autoconf
  • devel/automake
  • devel/bmake
  • devel/boost-build
  • devel/boost-docs
  • devel/boost-headers
  • devel/boost-jam
  • devel/buddy
  • devel/byacc
  • devel/ccache
  • devel/check
  • devel/chmlib
  • devel/cvs2cl
  • devel/cvs2html
  • devel/cvslock
  • devel/device-driver-doc-de
  • devel/dia2code
  • devel/doc++
  • devel/etrace
  • devel/exctags
  • devel/gettext-lib
  • devel/gettext-m4
  • devel/gettext-tools
  • devel/gflib
  • devel/gindent
  • devel/gmake
  • devel/gnome-common
  • devel/gobo-eiffel
  • devel/gperf
  • devel/idiff
  • devel/libcfg+
  • devel/libgetopt
  • devel/libiberty
  • devel/libjudy
  • devel/libltdl
  • devel/libmm
  • devel/libnet10
  • devel/liboop
  • devel/libportlib
  • devel/librfuncs
  • devel/librsync
  • devel/libslang
  • devel/libtecla
  • devel/libtool-base
  • devel/libwhisker2
  • devel/mph
  • devel/nspr-reference
  • devel/ossp-uuid
  • devel/p4-docs
  • devel/p5-Algorithm-Annotate
  • devel/p5-Algorithm-Dependency
  • devel/p5-Algorithm-Diff
  • devel/p5-Algorithm-Merge
  • devel/p5-App-CLI
  • devel/p5-AppConfig
  • devel/p5-AppConfig-Std
  • devel/p5-Array-Compare
  • devel/p5-AtExit
  • devel/p5-Attribute-Handlers
  • devel/p5-B-Keywords
  • devel/p5-BSD-Resource
  • devel/p5-Bit-Vector
  • devel/p5-Cache
  • devel/p5-Cache-Memcached
  • devel/p5-Cache-Simple-TimedExpiry
  • devel/p5-Carp-Assert
  • devel/p5-Carp-Assert-More
  • devel/p5-Carp-Clan
  • devel/p5-Class-Accessor
  • devel/p5-Class-Accessor-Chained
  • devel/p5-Class-Adapter
  • devel/p5-Class-Autouse
  • devel/p5-Class-Container
  • devel/p5-Class-Data-Inheritable
  • devel/p5-Class-ErrorHandler
  • devel/p5-Class-Factory
  • devel/p5-Class-Factory-Util
  • devel/p5-Class-Fields
  • devel/p5-Class-Gomor
  • devel/p5-Class-Inner
  • devel/p5-Class-Inspector
  • devel/p5-Class-Loader
  • devel/p5-Class-MakeMethods
  • devel/p5-Class-MethodMaker
  • devel/p5-Class-ObjectTemplate
  • devel/p5-Class-ReturnValue
  • devel/p5-Class-Singleton
  • devel/p5-Class-Std
  • devel/p5-Class-Trigger
  • devel/p5-Class-WhiteHole
  • devel/p5-Class-XML
  • devel/p5-Class-XPath
  • devel/p5-Clone
  • devel/p5-Clone-PP
  • devel/p5-Compress-Raw-Zlib
  • devel/p5-Compress-Zlib
  • devel/p5-Config-General
  • devel/p5-Config-IniFiles
  • devel/p5-Config-Std
  • devel/p5-Config-Tiny
  • devel/p5-Contextual-Return
  • devel/p5-Data-Buffer
  • devel/p5-Data-Dump
  • devel/p5-Data-Hierarchy
  • devel/p5-Data-OptList
  • devel/p5-Data-ShowTable
  • devel/p5-Data-TemporaryBag
  • devel/p5-Data-UUID
  • devel/p5-Date-Calc
  • devel/p5-Date-Manip
  • devel/p5-Date-Simple
  • devel/p5-Devel-Cycle
  • devel/p5-Devel-Profile
  • devel/p5-Devel-SmallProf
  • devel/p5-Devel-StackTrace
  • devel/p5-Devel-Symdump
  • devel/p5-Error
  • devel/p5-Event-RPC
  • devel/p5-Exception-Class
  • devel/p5-Expect
  • devel/p5-ExtUtils-AutoInstall
  • devel/p5-ExtUtils-CBuilder
  • devel/p5-ExtUtils-Depends
  • devel/p5-ExtUtils-F77
  • devel/p5-ExtUtils-MakeMaker
  • devel/p5-ExtUtils-ParseXS
  • devel/p5-ExtUtils-XSBuilder
  • devel/p5-File-BaseDir
  • devel/p5-File-DirSync
  • devel/p5-File-Find-Rule
  • devel/p5-File-Flat
  • devel/p5-File-FlockDir
  • devel/p5-File-HomeDir
  • devel/p5-File-MimeInfo
  • devel/p5-File-Modified
  • devel/p5-File-NFSLock
  • devel/p5-File-PathConvert
  • devel/p5-File-Slurp
  • devel/p5-File-Temp
  • devel/p5-File-Tempdir
  • devel/p5-File-Type
  • devel/p5-File-Which
  • devel/p5-File-chdir
  • devel/p5-FileHandle-Unget
  • devel/p5-FileKGlob
  • devel/p5-FreezeThaw
  • devel/p5-Getopt-ArgvFile
  • devel/p5-Getopt-Euclid
  • devel/p5-Getopt-Long
  • devel/p5-Getopt-Mixed
  • devel/p5-Getopt-Simple
  • devel/p5-Graph
  • devel/p5-Hash-Case
  • devel/p5-Heap
  • devel/p5-Hook-LexWrap
  • devel/p5-IO-All
  • devel/p5-IO-Capture
  • devel/p5-IO-Compress-Base
  • devel/p5-IO-Compress-Zlib
  • devel/p5-IO-Digest
  • devel/p5-IO-InSitu
  • devel/p5-IO-Interactive
  • devel/p5-IO-LockedFile
  • devel/p5-IO-Multiplex
  • devel/p5-IO-Null
  • devel/p5-IO-Pager
  • devel/p5-IO-Prompt
  • devel/p5-IO-String
  • devel/p5-IO-Stty
  • devel/p5-IO-Tee
  • devel/p5-IO-Tty
  • devel/p5-IO-Util
  • devel/p5-IO-Zlib
  • devel/p5-IO-stringy
  • devel/p5-IPC-Run
  • devel/p5-IPC-Shareable
  • devel/p5-Inline
  • devel/p5-List-MoreUtils
  • devel/p5-Log-Agent
  • devel/p5-Log-Dispatch
  • devel/p5-Log-Dispatch-Config
  • devel/p5-Log-Dispatch-DBI
  • devel/p5-Log-Dispatch-FileRotate
  • devel/p5-Log-LogLite
  • devel/p5-Make
  • devel/p5-Memoize
  • devel/p5-Memoize-ExpireLRU
  • devel/p5-Module-Build
  • devel/p5-Module-CoreList
  • devel/p5-Module-Install
  • devel/p5-Module-Install-RTx
  • devel/p5-Module-Install-Substitute
  • devel/p5-Module-Pluggable
  • devel/p5-Module-Refresh
  • devel/p5-Module-ScanDeps
  • devel/p5-Module-Starter
  • devel/p5-Module-Starter-PBP
  • devel/p5-Module-Versions-Report
  • devel/p5-NEXT
  • devel/p5-Net-CIDR
  • devel/p5-Net-Netmask
  • devel/p5-OLE-Storage_Lite
  • devel/p5-OOTools
  • devel/p5-Object-InsideOut
  • devel/p5-Object-Realize-Later
  • devel/p5-PAR-Dist
  • devel/p5-PPI
  • devel/p5-Params-Util
  • devel/p5-Params-Validate
  • devel/p5-Parse-RecDescent
  • devel/p5-Parse-Yapp
  • devel/p5-PatchReader
  • devel/p5-Path-Class
  • devel/p5-PathTools
  • devel/p5-Perl-Critic
  • devel/p5-Perl-Tidy
  • devel/p5-Perl6-Export
  • devel/p5-Perl6-Export-Attrs
  • devel/p5-Perl6-Slurp
  • devel/p5-PerlIO-eol
  • devel/p5-PerlIO-via-dynamic
  • devel/p5-PerlIO-via-symlink
  • devel/p5-Proc-Daemon
  • devel/p5-Proc-PID-File
  • devel/p5-Proc-Pidfile
  • devel/p5-Proc-ProcessTable
  • devel/p5-Proc-Simple
  • devel/p5-Readonly
  • devel/p5-Readonly-XS
  • devel/p5-Regexp-Assemble
  • devel/p5-Regexp-MatchContext
  • devel/p5-Regexp-Shellish
  • devel/p5-Return-Value
  • devel/p5-Rose-Object
  • devel/p5-SVN-Notify
  • devel/p5-Safe-Hole
  • devel/p5-Scalar-List-Utils
  • devel/p5-Schedule-RateLimiter
  • devel/p5-Set-IntSpan
  • devel/p5-Set-Scalar
  • devel/p5-Smart-Comments
  • devel/p5-Sort-Maker
  • devel/p5-Sort-Versions
  • devel/p5-Spiffy
  • devel/p5-Spoon
  • devel/p5-Storable
  • devel/p5-String-Format
  • devel/p5-Sub-Exporter
  • devel/p5-Sub-Install
  • devel/p5-Sub-Installer
  • devel/p5-Sub-Uplevel
  • devel/p5-Task-Weaken
  • devel/p5-Term-ProgressBar
  • devel/p5-Term-Prompt
  • devel/p5-Term-ReadKey
  • devel/p5-Term-ReadPassword
  • devel/p5-Term-Screen
  • devel/p5-Test-ClassAPI
  • devel/p5-Test-Cmd
  • devel/p5-Test-Deep
  • devel/p5-Test-Exception
  • devel/p5-Test-File-Contents
  • devel/p5-Test-Harness
  • devel/p5-Test-Inline
  • devel/p5-Test-LongString
  • devel/p5-Test-Manifest
  • devel/p5-Test-Memory-Cycle
  • devel/p5-Test-NoWarnings
  • devel/p5-Test-Object
  • devel/p5-Test-Perl-Critic
  • devel/p5-Test-Pod
  • devel/p5-Test-Pod-Coverage
  • devel/p5-Test-Simple
  • devel/p5-Test-Taint
  • devel/p5-Test-Tester
  • devel/p5-Test-Unit
  • devel/p5-Test-Warn
  • devel/p5-Tie-IxHash
  • devel/p5-Tree-DAG_Node
  • devel/p5-Tree-Simple
  • devel/p5-UNIVERSAL-moniker
  • devel/p5-UNIVERSAL-require
  • devel/p5-VCP
  • devel/p5-Want
  • devel/p5-WeakRef
  • devel/p5-capitalization
  • devel/p5-enum
  • devel/p5-gettext
  • devel/p5-perl-headers
  • devel/p5-prefork
  • devel/p5-version
  • devel/papaya
  • devel/patch
  • devel/pccts
  • devel/pedisassem
  • devel/pmccabe
  • devel/popt
  • devel/py-distutils
  • devel/ratfor
  • devel/rcs
  • devel/readline
  • devel/refinecvs
  • devel/rscode
  • devel/ruby-byaccr
  • devel/sgi-stl
  • devel/sgi-stl-docs
  • devel/silc-toolkit
  • devel/slib
  • devel/sparse
  • devel/swig
  • devel/sysexits
  • devel/tcllib
  • devel/tmake
  • devel/ucl
  • devel/ucpp
  • devel/vanessa_adt
  • devel/vanessa_logger
  • devel/vanessa_socket
  • devel/xfce4-dev-tools
  • devel/xmake
  • devel/z80-asm
  • devel/zlib
