Centrality Atlas II EVB Board Support Package#
This BSP supports the Centrality Atlas II EVB board.
Releases#
TRUNK#
| Date | Version | Prerequisites | Installation Notes | Release Notes | License(s) | Support | Provider | Download | Source Tag |
| Coming Soon! | trunk | QNX Momentics 6.4 | 6.4 Generic Notes | here | Apache II | Experimental | QNX | Coming Soon! | Coming Soon! |
QNX Neutrino 6.4#
| Coming Soon! | 1.0.0 | QNX Momentics 6.4 | 6.4 Generic Notes | here | Apache II | Experimental | QNX | Coming Soon! | Coming Soon! |
QNX Neutrino 6.3.2#
Features#
| Feature | Planned Availability | Format | Notes |
| Audio | Completed | SRC | . |
| Ethernet | Completed | SRC | . |
| Graphic | Completed | SRC | . |
| IPL | Completed | SRC | . |
| I2C | Completed | SRC | . |
| NAND | Completed | SRC | . |
| Serial | Completed | SRC | . |
| Startup | Completed | SRC | . |
| SD | Completed | BIN | . |
| USP | Completed | SRC | . |
| USB Host | Completed | BIN | . |
Some of these drivers are commented out in the default buildfile. To use the drivers in the target hardware, you'll need to uncomment them in your buildfile, rebuild the image, and load the image into the board.
TRUNK Change History#
Trunk#
- Created from QNX Neutrino 6.3.2 Centrality Atlas II BSP version 1.0.0
- Built using the latest 6.4 toolchain
6.4 Change History#
1.0.0#
6.3.2 Change History#
1.0.0#
- Initial release under MEULA
- Includes:
- IPL
- Graphics
- I2C
- Serial
- Startup
- NAND
- Ethernet
- audio
- USP
- USB Host
- SD
