Project: QNX RTOS v4
Forum Topic - io-usb problems: (4 Items)
View:  as
io-usb problems
I have some troubles with io-usb on a "new" fast motheboards when another PCI devise catch the interrupt number the same
 as io-usb interrupt number:
when I install USB Flash drive to USB socket - the QNX4 is blocked.
It is no problem when no PCI devise occupy interrupt the same as io-usb.
A there some plans to update io-usb and support USB 2.0?
P.s. USB support looks more stable and Plug & Play in QNX6.
Thank you
Re: io-usb problems
Hi Leonid,
Yes, io-usb update is in our plans for next year.
> another PCI devise catch the interrupt number the same as io-usb
> interrupt number: when I install USB Flash drive to USB socket - the
> QNX4 is blocked.
> io-usb.
> Thank you
> http://community.qnx.com/sf/go/post38014
Re: io-usb problems
Hi Oleg:
  I have experienced similar issues with the io-usb as well and would
welcome an update to resolve this as well.
 - Kevin
Oleg Bolshakov <community-noreply@qnx.com>
09/24/2009 04:32 AM
Please respond to
post38618@community.qnx.com
To
general-qnx4 <post38618@community.qnx.com>
cc
Subject
Re: io-usb problems
Hi Leonid,
> QNX4 is blocked.
> io-usb.
> Thank you
General
http://community.qnx.com/sf/go/post38618
Re: io-usb problems
To calrify this a little..
Once the 2009 CD is released we'll start a separate project to update USB support.  Once available we'll post
experimental versions to this foundry project.  This USB support will then be rolled into the next QNX 4 CD, which will
be approximatly 1 year after this one.  Late 2010 or early 2011.
-Martin
