Networking
Forum Topic - How to send ethernet raw packets in qnx 6.4 using libpcap?: (9 Items)
I want to send ethernet raw packets in QNX.
in linux we can use,
s = socket(AF_PACKET,SOCK_RAW,htons(ETH_P_ALL));
Since QNX doesn't support AF_PACKET. I cannot use this socket API in QNX.
In QNX forum I read that,  In io-pkt there is BPF / libpcap which should provide the same functionality.
Pls tell me how to send ethernet raw packets using BPF/libpcap in qnx 6.4?
Thanks...
RE: How to send ethernet raw packets in qnx 6.4 using libpcap?
The wiki is a good place to start reading about
io-pkt (6.4) and BPF:
http://community.qnx.com/sf/wiki/do/viewPage/projects.networking/wiki/Fi
ltering_wiki_page
It mentions that the tcpdump utility uses BPF.
In the io-pkt source tree, it is located in:
utils/t/tcpdump
I wish we had svn (and the indexer!) available
externally, so we could just give direct links.
Here is a bit more background on BPF:
http://www.rawether.net/support/bpf-usenix9.pdf
Hope this helps a bit,
aboyd
Re: RE: How to send ethernet raw packets in qnx 6.4 using libpcap?
Hi Andrew Boyd,
Thanks for ur reply.
I couldn't open
Its says "The page you requested cannot be found".
BVB
On Mon, Jan 05, 2009 at 04:06:51AM -0500, Beniz VB wrote:
> Hi Andrew Boyd,
> I couldn't open
http://community.qnx.com/sf/wiki/do/viewPage/projects.networking/wiki/Filtering_wiki_page
http://www.rawether.net/support/bpfhelp.htm
RE: RE: How to send ethernet raw packets in qnx 6.4 using libpcap?
For some reason unknown to me, you cannot view the
networking wiki pages unless you create a (free) user
account and log in (twice) - sorry about that  :-(
Here are some more links:
http://www.qnx.com/developers/docs/6.4.0/io-pkt_en/user_guide/filtering.
html#BPF
http://en.wikipedia.org/wiki/Berkeley_Packet_Filter
aboyd
Re: RE: RE: How to send ethernet raw packets in qnx 6.4 using libpcap?
Hi Andrew Boyd,
            I tried to send ethernet raw packets through BPF filter. I can able to send & receive ethernet packets. But
I couldn't implement the
filter in my program.  I have a doubt whether I should set the BPF filter in assembly level. Can you please send me one
example C code which can filter raw ethernet messages from the network (in QNX 6.4).
           In my sender program I'll send an ethernet frame (destination hardware (MAC) address [6bytes] + source
hardware (MAC) address [6 bytes]  + etherl type [2 bytes]  + payload [46 - 1500 bytes] +FCS [4 bytes].)
          In my ethernet frame, I'll put ethertype as 0x9999, inorder to identify it as my frame while receiving. So in
BPF receiver, I should capture frames which contain ethertype = 0x9999 only. Can u please tell me how to write a bpf
filter program in C for capturing my frame (QNX 6.4).
Thanks & Regards,
Beniz V B
RE: RE: RE: How to send ethernet raw packets in qnx 6.4 using libpcap?
> But I couldn't implement the filter in my program
Have you looked at the source in trunk/sys/utils/t/tcpdump ?
aboyd
Re: RE: RE: RE: How to send ethernet raw packets in qnx 6.4 using libpcap?
Hi Boyd,
      Thanks for your reply. I tried to implement the filter in my program. Now I have problem in ioctl(iHdl, BIOCSETF,
&my_bpf_program). It says invalid argument to ioctl.
        I'm attaching my code. Pls have a look at it and tell me what went wrong in my code.
        Is there any alternate solution to filter the ethernet raw packets based on ether type?
Beniz V B
Attachment: Text bpfreceiver.txt 2.79 KB
You'll notice that the e-mail interface to Foundry often breaks up long URLs, so you have to cut and paste the full text
 instead of only clicking on the link.
