Re: help with CM when using GF
08/13/2009 9:22 AM
post35907
When you look at the differences between the GF version and the same code converted to OpenKODE/EGL, you find that there
aren't that many differences. However, making those changes, even if there are just a few, isn't always easy...
The two big differences for GF apps rendering in OpenKODE windows are:
1) no layers; that's because with GF, the only "compositing" strategy is to use display controller layers. The
compositied windowing system that handles OpenKODE windows can use other hardware like 2D cores, VG cores, or 3D cores.
2) different surfaces; you have to use EGL surfaces and not GF surfaces.
If in the end each application has its own layer, you don't necessarily need the composited windowing system. The same
thing can be done with plain GF. However, OpenKODE also gives you better events, delegates (which can be used to control
other GF apps), and allows you to have multiple applications on the same layer (only one visible at any point in time).
All of this cannot be done using GF only.
http://community.qnx.com/svn/repos/graphics/trunk/apps/kd/tutorials/gf-kd-vsync/gf-kd-vsync.c is the OpenKODE equivalent
of http://community.qnx.com/svn/repos/graphics/trunk/apps/egl/tutorials/gf-egl-vsync/gf-egl-vsync.c
gf_draw_blit2 and gf_draw_blitscaled can still be used quite easily if one of the surfaces (source or destination)
isn't an EGL surface. If you need to blit from an EGL surface to another EGL surface, you have 4 options:
1) blitting can be done with a Khronos rendering API like OpenGL ES, or OpenVG. In this case, you cannot blit directly
from an EGL surface to another EGL surface. The source must be an object like a VGImage or a GL ES texture.
2) Use the EGL_QNX_gf_surface extension which will give you the gf_surface_t corresponding to the current renderbuffer
of an EGL surface. This obviously only works if the EGL_QNX_gf_surface extension is supported, which may not always be
the case.
3) Use the EGL_KHR_lock_surface extension, which allows software renderers to write their output to EGL surfaces. With
this extension, you can get a CPU accessible address, the stride, and the bit offsets of each color component of an EGL
surface. You can use gf_surface_attach and gf_surface_reattach to wrap it as a gf_surface_t. You will have to get the
rest of the information from other calls, i.e. eglQuerySurface to get the width and height, and eglGetConfigAttrib to
get the pixel format. Once an EGL surface is locked, it must be unlocked before you can do things with it, like
eglMakeCurrent or eglSwapBuffers. Each time a surface is locked, the pointer and stride returned could be different from
the last time. This is where gf_surface_reattach becomes useful...
4) Use eglCreatePixmapSurface for offscreen renderbuffers. The native pixmap is always a GF surface, which you can use
as argument to gf_draw_blit2 and gf_draw_blitscaled. The EGL surface can be used as argument to eglMakeCurrent, etc.
Now, getting back to square one, depending on what you are trying to do, there might be an easier approach than the
generic solutions I have outlined here.
