Community
Tracker
Forum Topic - Touchscreen on QNX6.4.1: Page 1 of 13 (13 Items)
Hi!Everyone,I try to run egalax touchscreen on QNX6.4.1.The file of touchscreen's driver about installed.
(Touchscreen driver Readme file)
Revision	: 1.01.5608
OS	: QNX Neutrino RTOS v6.3
Release Date	: 08-08-2006
File list:
TouchKit			- Utility
devi-eGalax		- RS232 Touch Screen Driver
input.localhost.txt		- Input Data
calib.localhost.txt		- Calibration Data
Notes:
     This Driver only support RS232.
1.  Copy "Touchkit" and "devi-eGalax" two files  to '/usr/photon/bin ' directory.
2.  Change it's Permissions and make it Executable.
3.  Open or Create "input.localhost" under '/etc/system/trap' and copy two lines to the file :
    		kbd fd -d/dev/kbd ps2 mousedev
    		devi-eGalax egalax fd -d/dev/ser1 abs
    Notes:
    	 "ser1" it means only support com1.You can change it to "ser2" to support com2.
4.  Open or Create "calib.localhost" under '/etc/system/trap' and copy the line to the file :
    		0x0:1023x767:0 2047 0 2047 0
When I do so that.I run
(1)#usb -vv
Device Address             : 1
Upstream Host Controller   : 1
Upstream Device Address    : 0
Upstream Port              : 0
Upstream Port Speed        : Full
Vendor                     : 0x0eef (eGalax Inc.)
Product                    : 0x0001 (USB TouchController)
Device Release             : r1.00
USB Spec Release           : v1.10
Serial Number              : N/A
Class                      : 0x00 (Independent per interface)
Max PacketSize0            : 64
Languages                  : 0x0409 (English)
Configurations             : 1
  Configuration            : 1 (eGalax Inc.)
    Attributes             : 0xa0 (Bus-powered, Remote-wakeup)
    Max Power              : 100 mA
    Interfaces             : 1
      Interface            : 0 / 0
        Class              : 0x03 (HID)
        Subclass           : 0x00
        Protocol           : 0x00
(2)#io-hid -degalax
(3)#devi-eGalax -vvvvvvvv egalax fd -d/dev/ser1 -b
Looking up egalax in module table
Allocated static module egalax at 8059660
Looking up fd in module table
Allocated static module fd at 80597a0
fd_parm: d
optarg: /dev/ser1
Looking up abs in module table
Allocated static module abs at 80599a0
Calibration filename: /etc/system/trap/calib.localhost
Adding filter module: abs
Resetting module fd
Opened a serial device
Resetting module egalax
Resetting module abs
Attempting to open calibration file: /etc/system/trap/calib.localhost
Did not find calib info for [639x479]
Calibration parameters
sxl : 0 sxh : 639
syl : 0 syh : 479
rxl : 0 rxh : 0
ryl : 0 ryh : 0
interrogate bus, returning abs
Attempting to determine graphics region dimensions
Found graphics region owned by local hardware
Graphics region dimensions are 0:0 799:599
Issuing devctrl to abs
Found calib info for [799x599]
sxl : 0 sxh : 799
syl : 0 syh : 599
rxl : 0 rxh : 799
ryl : 0 ryh : 799
Touch screen device driver received data from Photon server.
(4)#./Touchkit[Calibrate a touchscreen]
result:touchscreen nothing to do
my questions:
(1)The touchscreen and driver is matched?
(2)Touchscreen's driver install process is  correct?
(3)QNX6.4.1 touchscreen driver is supportted?
Thank you very much!
