Ralph Canapa(deleted)
Cannot get wklauncher to work in QNX as described in QNX Web Browser Engine Developer's Guide
02/25/2013 8:27 AM
post99503
I have a Flash (ActionScript 2) front-end running on a QNX system to control lights, temperature and some other features
. I'd like to support a webkit browser but I'm having problems displaying the browser correctly using the code provided
in examples. I can see that the webkit_kd process is running and I can get a browser screen to display launched by Flash
using the QNX-CAR code samples but there are problems with fonts and defining boundaries of the browser port.
So in an effort to handle one problem at a time I'm trying to see if I can get the webkit_kd browser to display local
pages without Flash running using the wklauncher application. However I cannot get it to work in QNX as described in the
QNX Web Browser Engine Developer's Guide.
Here's my procedure:
1) I've set LD_LIBRARY_PATH
2) I've verified that I have the proper files in $QNX_TARGET/opt/webkit/
3) I've executed $QNX_TARGET/opt/webkit/x86/bin/wklauncher file:\\\aLocalFolder\index.html
and I'm rewarded with:
gf_layer_attach() failed: No such process
GF init failed: are you running io-display?
BTW I'm running io-display
So, is there anyone who can give some guidance on how to solve this problem?
