Pekka Tuusjärvi(deleted)
09/25/2012 6:28 AM
post95786
We have used webserver vserver for our help manual. We have showed our help manual in a HTML as a part of our IDE. Now
in 6.5.0 it doesn´t work after we make a runtime image. What should I do?
Even in example VMWare image in QNX website the help doesn´t work. I attached a photo about the error message.
Max Feil
09/25/2012 7:45 PM
post95813
Can you show the contents of your /etc/photon/webservers file? Make sure that this file exists in your image, and that
the "help = ..." line properly references an existing executable.
Max
From: Pekka Tuusjärvi [mailto:community-noreply@qnx.com]
Sent: Tuesday, September 25, 2012 6:29 AM
To: general-web_browsers
Subject: Webserver/helpserver
General
http://community.qnx.com/sf/go/post95786
To cancel your subscription to this discussion, please e-mail general-web_browsers-unsubscribe@community.qnx.com
Re: RE: Webserver/helpserver
09/27/2012 2:21 AM
post95869
here is the file attached.
Max Feil
RE: RE: Webserver/helpserver
Max Feil
09/27/2012 3:01 PM
post95899
> help = mhelpserver,MozHelpServer
This is just the default line used for the self hosted help system. Is that what you intended? It means that the
executable "mhelpserver" must be in the runtime image and in a directory listed in $PATH. You can always specify an
absolute path here instead of updating $PATH.
Max
Sent: Thursday, September 27, 2012 2:22 AM
Subject: Re: RE: Webserver/helpserver
General
http://community.qnx.com/sf/go/post95869
Re: RE: RE: Webserver/helpserver
11/12/2012 4:23 AM
post97080
i managed get that error message away but it still wont work. My help is on xxx.htm file and mozilla shows it properly
when i open it straight from mozilla. If i pass the location of that file to ptwebclient it wont work. Any suggestions?
When i start the webclient its ok and no error message from Pt_ARG_WEB_STARTUP_ERRNO.
Here is the line from /etc/photon/webservers
online = /opt/Mozilla/mozilla/run-mozilla.sh /opt/Mozilla/mozilla/mozserver,MozillaServer
> what you intended? It means that the executable "mhelpserver" must be in the
> Max
> Hello,
Max Feil
RE: RE: RE: Webserver/helpserver
Max Feil
11/12/2012 3:26 PM
post97115
Are you setting Pt_ARG_WEB_SERVER to "online"? What is the exact URL you are passing in? I assume it begins with "file:/
/". Do other URL's work, say ones that aren't on the filesystem like http://google.com?
Also, obvious question: Do /opt/Mozilla/mozilla/run-mozilla.sh and /opt/Mozilla/mozilla/mozserver exist and look sane?
Max
Sent: Monday, November 12, 2012 4:23 AM
Subject: Re: RE: RE: Webserver/helpserver
> that what you intended? It means that the executable "mhelpserver"
> can always specify an absolute path here instead of updating $PATH.
> Max
> Hello,
General
http://community.qnx.com/sf/go/post97080
Re: RE: RE: RE: Webserver/helpserver
11/15/2012 2:32 AM
post97210
yes im setting that argument to "online". This code works in QNX 6.3.2 when I use the voyager.
online = vserver,VoyagerServer-2
Yes my URL is "file:///home/system/ohje.htm". It only shows white widget with every URL I try even http://google.com.
Those mozilla files exists because I copied them to my runtime afterwards. And I can surf in the web if I start the
mozilla browser with /usr/photon/bin/mozilla.
> passing in? I assume it begins with "file://". Do other URL's work, say ones
> Max
> xxx.htm file and mozilla shows it properly when i open it straight from
> suggestions? When i start the webclient its ok and no error message from
> MozillaServer
> > Max
> > Hello,
> > General
Max Feil
RE: RE: RE: RE: Webserver/helpserver
Max Feil
11/15/2012 7:25 PM
post97245
The Mozilla browser doesn't use the files you copied. From here it's hard to guess what might be wrong. Did you set
execute permissions on those 2 files you copied?
Sent: Thursday, November 15, 2012 2:32 AM
Subject: Re: RE: RE: RE: Webserver/helpserver
> you are passing in? I assume it begins with "file://". Do other URL's
> /opt/ Mozilla/mozilla/mozserver exist and look sane?
> Max
> is on xxx.htm file and mozilla shows it properly when i open it
> ptwebclient it wont work. Any suggestions? When i start the webclient
> /opt/Mozilla/mozilla/mozserver, MozillaServer
> > Is that what you intended? It means that the executable "mhelpserver"
> > Max
> > Hello,
> > General
> > general- web_browsers-unsubscribe@community.qnx.com
General
http://community.qnx.com/sf/go/post97210
