Forum Topic - cmake issue running the configure scripts on ubuntu 10.4: (5 Items)
I am new to cmake, and have an issue when i follow the webkit readme build instructions.  When I run the configure
script ../build-scripts/configure-owb x86 "" from webket/trunk/nto-x86-gf directory I get:
loading initial cache file ../cmake/ConfigureBuildGf.cmake
-- The CXX compiler identification is unknown
-- The C compiler identification is unknown
-- Check for working CXX compiler: /usr/bin/qcc
CMake Error: your CXX compiler: "/usr/bin/qcc" was not found.   Please set CMAKE_CXX_COMPILER to a valid compiler path
or name.
CMake Error: Internal CMake error, TryCompile configure of cmake failed
-- Check for working CXX compiler: /usr/bin/qcc -- broken
CMake Error at /usr/share/cmake-2.8/Modules/CMakeTestCXXCompiler.cmake:43 (MESSAGE):
  The C++ compiler "/usr/bin/qcc" is not able to compile a simple test
  program.
  It fails with the following output:
  CMake will not be able to correctly generate this project.
Call Stack (most recent call first):
  CMakeLists.txt:7 (project)
or name.
CMake Error: your C compiler: "/usr/bin/qcc" was not found.   Please set CMAKE_C_COMPILER to a valid compiler path or
name.
-- Configuring incomplete, errors occurred!
I know gcc and g++ are working an reside in /usr/bin  so I have not been able to determine why cmake cannot find the
compilers.  Anyone have any ideas on what is wrong and how to fix it?
The cmake web site talks about a the need for a CMakeLists.txt file, which I cannot find anywhere under opt/web-browsers
Re: cmake issue running the configure scripts on ubuntu 10.4
attached is the cache file that was generated
Attachment: Text CMakeCache.txt 11.34 KB
RE: cmake issue running the configure scripts on ubuntu 10.4
Your $QNX_HOST environment variable is not set, so maybe you don't have
the QNX SDP installed? Or if you just recently installed it, you have
not logged out and then back in to make sure the environment variables
get set in new shells.
From: Darrin Garrett [mailto:community-noreply@qnx.com]
Sent: Wednesday, September 01, 2010 12:00 PM
To: general-web_browsers
Subject: cmake issue running the configure scripts on ubuntu 10.4
build instructions.  When I run the configure script
directory I get:
set CMAKE_CXX_COMPILER to a valid compiler path or name.
CMake Error at
  program.
CMAKE_C_COMPILER to a valid compiler path or name.
able to determine why cmake cannot find the compilers.  Anyone have any
which I cannot find anywhere under opt/web-browsers.
General
http://community.qnx.com/sf/go/post65509
Re: RE: cmake issue running the configure scripts on ubuntu 10.4
By SDP you mean Software Development Platform?
QNX SDP is installed at /opt/qnx641
Momentics works.
from env I get:
QNX_HOST=/opt/qnx641/host/linux/x86
it seems cmake was not changing the cache file and I needed to manually change it so all the compiler paths pointed to
the correct location for gcc and other output directories.
The configuration script is working now.
