Forum Topic - owb linker error: (5 Items)
owb linker error
I am trying to build the latest OWB for SDL CAIRO surface instead of GF on QNX . I could build wtf ,Javacore & WebCore.
When I build for target owb target. I am getting the linker error as mentioned below. Do you have any comment on this
linker error ?
#make owb
[0%] Built target wtf
[7%] Built target jsc
[96%] Built target webcore
Linking CXX shared library ../../lib/libwebkit-owb.so
/usr/qnx641/host/qnx6/x86/usr/bin/ntox86-ld: failed to set dynamic section sizes: Memory exhausted
cc: /usr/qnx641/host/qnx6/x86/usr/bin/ntox86-ld error 1
make[3]: *** [lib/libwebkit-owb.so.2.0] Error 1
make[2]: *** [WebKit/OrigynWebBrowser/CMakeFiles/webkit-owb.dir/all] Error 2
make[1]: *** [WebKitTools/OWBLauncher/CMakeFiles/owb.dir/rule] Error 2
make: *** [owb] Error 2
-satish
Re: owb linker error
I got rid of this error after turning off the DEBUG flag.
Satish P
RE: owb linker error
In case anybody is interested, the problem was not enough memory
installed on the build machine. The README with the build instructions
gives some guidance on this.
Max
From: satish pattar [mailto:community-noreply@qnx.com]
Sent: Monday, February 08, 2010 4:29 AM
To: general-web_browsers
Subject: Re: owb linker error
Satish P
General
http://community.qnx.com/sf/go/post46745
Re: RE: owb linker error
Hello Max,
owb README says:
Debugging on armle may only working by doing a release build
and changing O2 and O3 to O0 in the following files created by configure:
flags.make (6 files, multiple occurences)
It doesn't say anything about x86 DEBUG build issue.
For me , release build for SDL build works fine & owb is also launching.
but for debug build Memory exhaust problem.
Is it some problem with  my build ? or is it something else ?
Your inputs are appreciated.
Satish P
RE: RE: owb linker error
If you are running out of memory at build time, you need to add more
memory to your build machine. The armle problem in the readme was a case
I encountered early on and occurred on the target.
Sent: Friday, February 19, 2010 8:22 AM
Subject: Re: RE: owb linker error
Hello Max,
owb README says:
configure:
Satish P
General
http://community.qnx.com/sf/go/post47748
