Rick Duff
Re: Welcome to the Vmware General Forum
Rick Duff
09/25/2007 11:19 AM
post1574
> I don't want to sound to nieve, but I would like to know a bit more about why
> and what development is needed for QNX 6.3 under VMware. Is there such a
> thing as a virtual driver, say for video or hard drive, that is specific to
> VMware? Also, what is this vmtoold you are refering to?
Yes, there are specific drivers which can be written to "know" they are in a vm and are better at accelarating because
of that. devg-vmware.so is an example (video driver).
vmtoold is a program which myself and others wrote a couple years ago which provides some of the functionality that
VMware had been providing for other guest OSs. In particular, it syncs the time between the host and guest OS. It also
shares (somewhat lamely) the clipboard between the two - you can cut in QNX and paste in Windows and vice versa.
Lastly it manages grabbing and ungrabbing the mouse so you can quickly move between QNX and Windows without any extra
keystrokes (which is the default).
> While we're on the subject, could a QNX 6.3 network be created between two QNX
> VM's inside of VMware, or even between one inside and one outside?
I have created a network of QNX virtual instances running on my laptop to demonstrate a shared distributed database
application I wrote - so yes. We also use it to connect to our external hardware (via serial or tcpip) occasionally.
> Finally, is there a particular host for VM that works best, ie. Linux vs. XP?
I have only played with the Windows version so I can't comment on that. If they used the same license for both, I could
experiment, but right now I need to use Windows (at work anyway), so this gives me the best of both.
Rick..
Mario Charest
Mario Charest
09/26/2007 10:45 AM
post1615
I once had 4 QNX4 vm machines running at the same time and exchanging data ( for testing automap )
Browsing the VmWare forum it seems XP is best. Some recommend having a separate HD to hold the vm filesystem. Also
lots of RAM is the key.
James VanOeffelen
James VanOeffelen
10/05/2007 3:03 PM
post1826
Hi all. XP seems to be the best platform for running VMware. I run VM WS6 on an x64 XP Pro machine. Using the x64 allows
me to install more memory (currently at 8GB). I have created a VM Team consisting of eight virtual machines (1 2003
Server, 1 XP Pro, and 6 QNX 6.3. I have two virtual networks setup. All QNX VM's talk over virtual LAN 2. One of the QNX
VM's has a seond virtual NIC that is used to talk to the Windows VM's.
All works great.
