Source Code
Source Code
Forum Topic - Self-hosted toolchain for non-x86?: (3 Items)
Since the pkgsrc project only supports building on self-hosted QNX systems...
Is it feasible to create a self-hosted toolchain that can run on a non-x86 QNX machine (e.g., ppcbe)? I'm guessing
somebody has at least attempted this at some point... any pointers on where to start?
Alternatively, do you guys have non-x86 self-hosted versions available internally that our support rep could get for us?
Josh
Re: Self-hosted toolchain for non-x86?
us?
No, we don't use native non-x86 toolchains internally.
To start with, check out the binutils and gcc from the foundry, and use
the existing compilers to configure and build binutils and gcc for a ppc
host. e.g. --host=powerpc-unknown-nto-qnx6.4.0
--target=powerpc-unknown-nto-qnx6.4.0
Building binutils for your target should be straightforward. Building
gcc will be slightly more complicated. If you're building gcc 4.3.3 or
newer, you'll have to cross compile gmp and mpfr for your target as
these are now needed for cc1/cc1plus.
It may be easier for you to cross-compile the project(s) you want to
build from pkgsrc then going to through the hassle of setting up a
native toolchain for your target.
Ryan Mansfield
 us?
There's also all sorts of other utilities pkgsrc
expects that are only shipped self hosted...
