Neil Schellenberger(deleted)
Re: Problems with 6.4.1 make backslash-newline: "./\: is a
directory"
08/19/2009 11:14 AM
post36280
directory"
On Wed, 2009-08-19 at 11:06 -0400, Josh Radel wrote:
> The version of make included with the 6.4.1 release seems to have problems interpreting backslash-newline command
separators. Take the attached simple makefile as an example. Under the 641 environment, typing "make" outputs:
Yes, you've run afoul of a backward incompatibility between 3.80 and
3.81. From the 3.81 NEWS file (which I've also attached in full):
* WARNING: Backward-incompatibility!
In order to comply with POSIX, the way in which GNU make processes
backslash-newline sequences in command strings has changed. If your
makefiles use backslash-newline sequences inside of single-quoted
strings in command scripts you will be impacted by this change. See
the GNU make manual subsection "Splitting Command Lines" (node
"Splitting Lines"), in section "Command Syntax", chapter "Writing the
Commands in Rules", for details.
Neil
Attachment: |
NEWS
42.86 KB
lolo lololo
Re: Problems with 6.4.1 make backslash-newline: "./\: is a directory"
lolo lololo
10/28/2009 4:52 PM
post40941
I have exactly the same issue with a makefile which was well working on QNX6.3.2. I am interested in any informations.
Thanks.
