Source Code
Source Code
Forum Topic - Convert ELF to Bin?: (5 Items)
Convert ELF to Bin?
Hey all,
I would like to convert my kernel image cwc.ifs to a binary file that is executable starting at instruction 0. The mkrec
 utility simply encodes whatever you give it in S-record format, but it does no conversion of the object, so what I end
up with is an Elf file encoded as a bunch of S-records. When I TFTP this to my target, the Elf file gets placed in flash
, Elf header and all. What I really want is to convert Elf to Bin, then encode the Bin in S-record format.
"Building Embedded Systems" mentions using objcopy to do this conversion, but the standard objcopy that comes with Linux
 builds an image that won't boot (even though objcopy claims to understand big-endian Elf). Do I need a special cross-
objcopy that understands PPC opcodes? Which objcopy are you guys using? Can anyone recommend something that will run
under Linux & handle PPC object code?
-Jon
Re: Convert ELF to Bin?
The normal image doesn't have an entry point as offset 0 - you want to
use raw.boot - the first instruction will find and jump to the entry point
of the startup.
change
[virtual=ppc,elf]
to
[virtual=ppc,raw]
in your build file.
Cheers,
Colin
Jonathan Juniman wrote:
> Hey all,
> executable starting at instruction 0. The mkrec utility simply encodes
> the object, so what I end up with is an Elf file encoded as a bunch of
> flash, Elf header and all. What I really want is to convert Elf to Bin,
> conversion, but the standard objcopy that comes with Linux builds an
> big-endian Elf). Do I need a special cross-objcopy that understands PPC
> something that will run under Linux & handle PPC object code?
> Thanks,
> -Jon
> http://community.qnx.com/sf/go/post7501
cburgess@qnx.com
OK, before, the line in my build file said:
[virtual=ppcbe,elf +compress]
So I would let it build an Elf file, then convert to S-record with mkrec. For some reason, mkrec prepended two bytes of
garbage 0x90 0x90 to the start of the Elf image. But no matter. I could get the entry point out of the Elf header, then
boot it by copying from flashaddr+2 to RAM, and jumping to the known entry point. This works.
So now I changed the build file to:
[virtual=ppcbe,raw +compress]
When I run it through mkrec, it still prepends 0x90 0x90 to the image. I TFTPed it to the board and tried it both ways:
copying from flashaddr+2 to RAM (to strip the garbage bytes), and copying from flashaddr to RAM (to leave the garbage
bytes). The image won't boot either way.
Do I need some tech support help on this one?
Never mind, it works. The manufacturer's BIOS has some quirk where the boot-up never works the first time after you've
flashed it. This did the trick! Thanks!
Cool :-)
> boot-up never works the first time after you've flashed it. This did the
> trick! Thanks!
> http://community.qnx.com/sf/go/post7513
cburgess@qnx.com
