Core Development Tools
Source Code
Forum Topic - Memory fault - coredump: (3 Items)
We are running a small pogram in QNX6.3.2 using Boost library.
The program is:
#include <iostream>
#inlcude <boost/filesystem.hpp>
using namespace std;
namespace fs = boost::filesystem;
int main ()
   if ( fs::exists("/bbb.xml"))
         cout << " File exists" << endl;
   else
        cout << " File does not exist" << endl;
   return 0;
and the makefile as:
all : test
test : test.o
       ntox86-g++-3.3.5 test.o -I/usr/local/lib -lboost_filesystem-d -o test
test.o : test.cpp
       ntox86-g++-3.3.5 -c -I/usr/local/include/boost-1_34_1 test.cpp
and we got the executable file as test.
Now when we run test as ./test, its giving <Memory fault>coredump.
How can we will get the output instead of coredump? any help.
Lakshmi.
Re: Memory fault - coredump
> The program is:
> #include <iostream>
> int main ()
>    else
>    return 0;
> all : test
> test : test.o
> test.o : test.cpp
> Regards,
> Lakshmi.
Hi Lakshmi,
I will try to reproduce the crash for you and debug it. Can you confirm how you built boost?
It may be helpful for you to familiarize yourself with gdb -- it is the best way to debug unexpected program behavior.
Ryan Mansfield
> > Hi,
> > The program is:
> > #include <iostream>
> > int main ()
> >    else
> >    return 0;
> > all : test
> > test : test.o
> > test.o : test.cpp
> > Regards,
> > Lakshmi.
> Hi Lakshmi,
> you built boost?
I'm guessing you switch the toolset to be qcc. In that case, the libboost-filesystem.so was built against libcpp
(Dinkumware C++ library) and when you link with the gcc driver (ntox86-g++-3.3.5) you link against the GNU C++ library
so you end up linking against both C++ libraries.
If you built Boost with qcc, you should be using qcc for your project. If you built Boost with gcc, you should be using
the gcc driver for your project.
For example:
# ntox86-g++-3.3.5 -I/usr/local/include/boost-1_34_1 boost.cc  -L/usr/local/lib -lboost_filesystem-d
# ./a.out
Memory fault (core dumped)
# qcc -V3.3.5,gcc_ntox86 -I/usr/local/include/boost-1_34_1 boost.cc  -L/usr/local/lib -lboost_filesystem-d
# ./a.out
 File does not exist
# touch /bbb.xml
# ./a.out
 File exists
Ryan Mansfield
