Source Code
Source Code
Forum Topic - CVS issues: (1 Item)
CVS issues
Hi all,
In a QNX 6.3.2 I set up a CVS 1.11.9, the one that comes with the OS. It = has no password auth, and works fine in
client/server from other QNX6 = hosts. Integration with Eclipse is good too, btw.
In a QNX 4.25 I install a CVS 1.7 client, the only version I found that = compiles without many tweaks.=20
So I can't connect to the QNX6 server from the QNX4 client. I get this:
qnx4$ cvs -d :ext:user@qnx6:/usr/cvs checkout .
Host name lookup failure
cvs [checkout aborted]: premature end of file from server
The Cederqvist says that is an rsh error, but I get the same result with = other access methods. rsh/rlogin work well on
 their own and can find the = cvs executable. Trying to debug setting up CVS_CLIENT_LOG I find the = clog.out file empty
. CVS protocols versions 1.7 and 1.11 are supposed to = be compatible.
Any ideas?
Thank you for your time... and happy new year 2010!
