Christian Damus(deleted)
Problem running Neutrino binary compiled from IBM Rhapsody
12/14/2009 12:44 PM
post43826
Forwarded from the IDE forum:
--------8<--------
hello,
I am compiling an IBM rhapsody (v7.5) application for an arm target (freescale i.MX25) running QNX 6.4.1. The
compilation runs ok, but when i try to run the binary on the target, i get the following error
terminate called after throwing an instance of '__gnu_cxx::__concurrence_broadcast_error'
what(): __gnu_cxx::__concurrence_broadcast_error
I can run applications that I creates as QNX c++ applications using momentics. So i am wondering if I am linking
incorrectly? I added the link command below. Would be thankful for any suggestions or ideas. Thank you
Marcel
C:/QNX641/host/win32/x86/usr/bin/ntoarm-ld -EL -m armnto -p --dynamic-linker /usr/lib/ldqnx.so.2 C:/QNX641/target/qnx6/
armle/lib/crt1.o C:/QNX641/target/qnx6/armle/lib/crti.o C:/QNX641/host/win32/x86/usr/lib/gcc/arm-unknown-nto-qnx6.4.0/4.
3.3/crtbegin.o MainDefaultComponent.o Hello.o C:/Programme/IBM/Rational/Rhapsody/7.5/Share/LangCpp/lib/QNX641oxfarmle.a
C:/Programme/IBM/Rational/Rhapsody/7.5/Share/LangCpp/lib/QNX641simulinkintegrationarmle.a -Bstatic -lm -lcpp -o
DefaultComponent -rpath-link C:/QNX641/target/qnx6/armle/lib:C:/QNX641/target/qnx6/armle/usr/lib:C:/QNX641/target/qnx6/
armle/lib/gcc/4.3.3:C:/QNX641/target/qnx6/armle/opt/lib -Y/cygdrive/C/QNX641/target/qnx6/armle/lib:/cygdrive/C/QNX641/
target/qnx6/armle/usr/lib:/cygdrive/C/QNX641/target/qnx6/armle/opt/lib -LC:/QNX641/host/win32/x86/usr/lib/gcc/arm-
unknown-nto-qnx6.4.0/4.3.3// -LC:/QNX641/target/qnx6/armle/lib/gcc/4.3.3 -LC:/QNX641/target/qnx6/usr/arm-unknown-nto-
qnx6.4.0/lib// -LC:/QNX641/target/qnx6/armle/lib -LC:/QNX641/target/qnx6/armle/usr/lib -LC:/QNX641/target/qnx6/armle/opt
/lib -lcpp -lcxa C:/QNX641/host/win32/x86/usr/lib/gcc/arm-unknown-nto-qnx6.4.0/4.3.3///libgcc.a -lcxa -lc -dn -Bstatic -
lc C:/QNX641/host/win32/x86/usr/lib/gcc/arm-unknown-nto-qnx6.4.0/4.3.3///libgcc.a C:/QNX641/host/win32/x86/usr/lib/gcc/
arm-unknown-nto-qnx6.4.0/4.3.3/crtend.o C:/QNX641/target/qnx6/armle/lib/crtn.o
-------->8--------
