Preet Desai
libstdc++ and qt with Qnx 6.5.0 tools (gcc 4.4.2)
Preet Desai
06/03/2012 4:46 PM
post93476
Hiya,
I'm trying to do some dev for the playbook using ndk 2.0.1 that rim released awhile ago. It provides libstdc++ along
with gcc 4.4.2 based tools. I'm also using qt for my application. The problem I'm having is that qt and libstdc++ seem
to work fine independently, but when I link to both of them in the same application, I get a segmentation fault. Note
that I don't need to actually use any Qt code, just linking it in is enough to cause a crash.
Here's a sample application:
#include <iostream>
#include <sstream>
int main(int argc, char *argv[])
std::cout << "This doesn't work\n";
return 0; // i think it crashes here when the os tries to do cleanup
Here's the stack trace from the crash:
#0 0xb8b5e329 in __gnu_cxx::__exchange_and_add (__mem=0x0, __val=-1)
at atomicity.cc:36
36 atomicity.cc: No such file or directory.
in atomicity.cc
(gdb) backtrace
at atomicity.cc:36
#1 0xb8b03471 in __exchange_and_add_dispatch (__val=<optimized out>,
__mem=<optimized out>)
at /home/builder/hudson/650-gcc-4.4/svn/linux-x86-o-ntox86/i486-pc-nto-qnx6.5.0/pic/libstdc++-v3/include/ext/
atomicity.h:79
#2 _M_remove_reference (this=<optimized out>)
at /home/builder/hudson/650-gcc-4.4/svn/linux-x86-o-ntox86/i486-pc-nto-qnx6.5.0/pic/libstdc++-v3/include/bits/
locale_classes.h:505
#3 std::locale::~locale (this=0xb837d5fc, __in_chrg=<optimized out>)
at ../../../../../libstdc++-v3/src/locale.cc:89
#4 0xb8b0faa9 in ~basic_streambuf (this=<optimized out>,
at /home/builder/hudson/650-gcc-4.4/svn/linux-x86-o-ntox86/i486-pc-nto-qnx6.5.0/pic/libstdc++-v3/include/streambuf:
193
#5 std::basic_filebuf<char, std::char_traits<char> >::~basic_filebuf (
this=0xb837d5e0, __in_chrg=<optimized out>)
at /home/builder/hudson/650-gcc-4.4/svn/linux-x86-o-ntox86/i486-pc-nto-qnx6.5.0/pic/libstdc++-v3/include/fstream:215
#6 0xb0bbd205 in __cxa_finalize ()
from /home/preet/bbndk-2.0.1/target/qnx6/x86/lib/libc.so.3
#7 0xb832de67 in _btext ()
from /home/preet/bbndk-2.0.1/target/qnx6/x86/lib/libcpp.so.4
#8 0xb836a265 in _fini ()
#9 0xb0bd46d3 in ?? ()
#10 0xb0bd5d38 in ?? ()
#11 0xb0bbd052 in _cleanup ()
#12 0xb0bbd337 in exit ()
#13 0x080487b0 in _start ()
I'd appreciate any feedback or advice.
