Qt
Forum Topic - X server configuration?: (7 Items)
I'm not sure whether I should post this question here, but I at least it's related to Qt..
Recently I'm trying to setup the running and building environment for Qt and qwt in QNX.
And I find X server is required to make this happen.
So I installed some packages from pkgsrc, following are the list:
modular-xorg-apps-1.5 Modular Xorg application meta-package
modular-xorg-fonts-1.1 Modular Xorg font meta-package
modular-xorg-libs-1.0nb1 Modular Xorg library meta-package
modular-xorg-server-1.6.5nb9 Modular X11 server from modular X.org
xf86-input-vmmouse-12.6.6nb1 Modular Xorg VMware virtual mouse driver
xf86-input-mouse-1.4.0nb2 Modular Xorg mouse driver
xf86-video-nv-2.1.18 Modular Xorg NVIDIA video driver
xf86-video-vmware-10.16.9nb1 Modular Xorg VMware virtual video driver
I know it's a silly question but I don't know how to use this X server...
Can any one tell me how to configure this thing?
BTW: My QNX6.5.0 runs in VMWare.
Thanks!
Br
Zhiying
Re: X server configuration?
The X server X XPhoton could be a alternative:
http://sourceforge.net/projects/openqnx/files/xphoton.4.3/
But are you awarte about this project?
http://community.qnx.com/sf/projects/qt
Regards
--Armin
http://www.steinhoff-automation.com
> Thanks!
> Br
> Zhiying
> Qt General
> http://community.qnx.com/sf/go/post88566
Hi Armin, thanks for your advice, but even if I can install Xphoton, still I have no idea how to use it, just like X
server...
Hi Dennis, the examples in qwt-6.0.1 do work without X server!
So maybe it is the version of qwt I used before(qwt-5.2.1 from pkgsrc) that caused the failure to run the examples ?
The pkgsrc version of qwt is targeting a desktop - the newer version (6.x) is targeting "Qt embedded" - which matches
the Qt package associated with this F27 project.
server...
You have to start it in normal X server environment .... no
configuration needed. qwt works with Xphoton ...
--Armin
> Qt General
> http://community.qnx.com/sf/go/post88610
Zhiying-
Armin's xphoton sounds like a good suggestion, but I was able to download and run the examples WITHOUT X.  In fact,
since it is looking for X implies a problem - that means it is NOT looking to use the "Qt Embedded" model!  From the
INSTALL file...
D) Qt Embedded
I only tested Qwt with Qt Embedded in qvfb (Virtual Framebuffer Devivce)
Emulator on my Linux box. To build Qwt for the emulator was as simple as
for a regular Unix build.
This is the model required for QNX.
Here is what I did... ON SELF-HOSTED 6.5 - using a PC - that was already setup to build and run Qt binaries,
1) Downloaded http://surfnet.dl.sourceforge.net/project/qwt/qwt/6.0.1/qwt-6.0.1.zip
2) Unzipped archive to /qwt
3)  From a shell...
# cd /qwt/qwt-6.0.1
# qmake
# make
# install
# cd /qwt/qwt-6.0.1/examples/dials
# qmake
# make
4) To run the example, telnet into the pc, and run
# devi-hid -Pr mouse kbd
# ../.bin/dials -qws &
Thats it!
Dennis
Dennis,
just to point out that the embedded version of Qt doesn't support the integration with Photon.
--Armin
> Zhiying-
> run the examples WITHOUT X.  In fact, since it is looking for X implies a
> the INSTALL file...
> D) Qt Embedded
> 1.zip
> 3)  From a shell...
> # cd /qwt/qwt-6.0.1
> # qmake
> # make
> # install
> # qmake
> # make
> Thats it!
> Dennis
