Qt
Forum Topic - Qt unable to run qtdemo: (8 Items)
I have a problem running qtdemo on QNX 6.5.0 with QT4.7.1 downloaded from QNX webpage (link File Releases on this
website)
The QNX is a default installation on x86 pc with following pci graphic card:
Vendor ID      = 1002h, ATI Technologies Inc
Device ID      = 5446h,  Rage 128 Pro Ultra TF
PCI index      = 0h
BAR - 0 [Mem]  = f4000000h enabled
BAR - 1 [I/O]  = d800h enabled
BAR - 2 [Mem]  = f3000000h enabled
PCI Expansion ROM = f3fe0000h disabled
PCI Int Pin    = INT A
Interrupt line = 11
CPU Interrupt  = bh
I do the following steps to start the demo:
- start QNX in text mode (no Photon running)
- login as root
- export following stuff in my .profile of root
QWS_DISPLAY=qnx
QWS_KEYBOARD=qnx
QWS_MOUSE_PROTO=qnx
export QWS_DISPLAY
export QWS_KEYBOARD
export QWS_MOUSE_PROTO
- start qtdemo as "./qtdemo -qws"
- and get the following error:
# ./qtdemo -qws
QQnxScreen: Attached to Device, number of displays: 1
QQnxScreen: Attached to Display 0, resolution 1280x1024, refresh 60 Hz
qnx: driver cannot connect
Abort (core dumped)
I also tried to run "vsync" program, which worked and printed following message:
# vsync
Number of displays: 1
Display 0: 1280X1024, refresh = 60Hz
Number of layers: 2
My ps -A tells following (maybe something wrong is running):
# ps -A
       PID TTY          TIME CMD
         1 ?        00:23:53 procnto-smp-instr
         2 ?        00:00:00 tinit
      4099 ?        00:00:00 pci-bios
      4100 ?        00:00:00 slogger
      4101 ?        00:00:00 io-usb
      4102 ?        00:00:00 io-hid
      4103 ?        00:00:00 devc-con-hid
      8200 ?        00:00:09 devb-eide
     20489 ?        00:00:00 pipe
     24586 ?        00:00:00 mqueue
     53259 ?        00:00:00 mcd
     57356 ?        00:00:00 random
     61453 ?        00:00:00 enum-devices
    159758 ?        00:00:00 devc-ser8250
     90127 ?        00:00:00 devc-ser8250
     77840 ?        00:00:00 enum-usb
    159761 ?        00:00:00 dhcp.client
     90130 ?        00:00:00 devc-par
    167955 ?        00:00:00 devc-pty
     94228 ?        00:02:30 io-display
    110613 ?        00:00:00 io-pkt-v4-hc
    180246 ?        00:00:01 dumper
    544791 ?        00:00:00 sshd
    196632 ?        00:00:00 -sh
    196633 ?        00:00:00 login
    196634 ?        00:00:00 login
    196635 ?        00:00:00 login
    331804 ?        00:00:00 sshd
    552989 ?        00:00:00 sshd
    552990 ?        00:00:00 -sh
    712735 ?        00:00:00 sh
    794656 ?        00:00:00 ps
I also tried to slay io-display and restart it with "# io-display -d vid=0x1002,did=0x5446"
same result:
# ./qtdemo -qws"
Abort (core dumped)
Do somebody have any idea what could be the problem here?
By the way: I also tried the same in VirtualBox with the same results.
Many Thanks!
Max
Re: Qt unable to run qtdemo
Max-
Since you are on the default 6.5 install, please launch photon, change the display driver to "SVGA" and exit photon.
 This should leave io-display with the "devg-svga.so" loaded.  You can verify by running "pidin mem" and looking at the
shared objects loaded by process io-display.
Now try "qtdemo -qws" - it should work on svga (though slow).
If this works, then for some reason, Qt is incompatible with the rage driver and/or your hardware.
Dennis
Hello Dennis,
thanks for the quick reply!
I've tried your suggestion and set the display driver to svga, but the problem stays the same.
pidin mem:
   94228   1 sbin/io-display     10o SIGWAITINFO       48K 3932K   20K(516K)*
   94228   2 sbin/io-display     12o RECEIVE           48K 3932K  8192(132K)
   94228   3 sbin/io-display     12o RECEIVE           48K 3932K  8192(132K)
   94228   4 sbin/io-display     10o RECEIVE           48K 3932K  4096(132K)
   94228   5 sbin/io-display     10o RECEIVE           48K 3932K  4096(132K)
   94228   6 sbin/io-display     10o RECEIVE           48K 3932K  8192(132K)
            libc.so.3          @b0300000             488K   16K
            devg-svga.so       @b8200000              32K  4096
            libffb.so.2        @b8209000             172K  8192
            em/ctl-1002,5446,0 @40100000 (       0)        4096
# ./qtdemo -qws
QQnxScreen: Attached to Display 0, resolution 640x480, refresh 60 Hz
Abort (core dumped)
I had the same suspicion before, that’s why I've tried to run it in VirtualBox but it looks the same.
Max
has someone more ideas for this? Is somebody running QT with QNX 6.5?
Max
The string "driver cannot connect" comes from libQtGui.so.  (Mine is 13351084 bytes)
The source file is qui\embedded\qscreen_qws.cpp.. maybe build with some debug printf's?
Problem solved :)
It was the Color Mode. The problem only occurs with 32K (+1 bit alpha). No difference if we use our ati driver or svga.
how you set the Color mode?
64K
