Jim Douglas
Re: Windows IDE examples?
Jim Douglas
04/15/2011 12:28 PM
post85053
Download the various packages and extract the header, library and make files into your SDK directories (usually c:\
QNX650 in Windoze). Create makefile projects in the IDE and extract the source files into them. Then just build the
projects.
I have also managed to compile a trivial example from a tutorial, but I have yet to get it to run on a target machine.
I need some help setting up the runtime environment.
Jim
Freddy Martens
Freddy Martens
07/01/2011 3:16 AM
post87012
Hi Tom,
Take a look at: http://community.qnx.com/sf/discussion/do/listPosts/projects.qt/discussion.general.topc20245
You need to extract the Qt zipfile to your developement environment. Then you need to run a dos script (http://community
.qnx.com/sf/sfmain/do/downloadAttachment/projects.qt/discussion.general.topc20245/post86853?id=atch10861) to fix the
files since symlinks do not work on windows. Now you need to create a standard c++ makefile project as indicated. After
creating the project, copy the sources to this folder. The second last step is to get this makefile: http://community.
qnx.com/sf/sfmain/do/downloadAttachment/projects.qt/discussion.general.topc20245/post86854?id=atch10862 and build the
binary.
I hope this also works for you. I am using the binaries on a IGEPv2. Don't forget to include the shared objects on your
target and set the environment variables on your target. Make sure that the env var TMPDIR points to a QNX4 partition.
Freddy
