Qt
Forum Topic - Building examples: Page 1 of 5 (5 Items)
Building examples
Is it possible to build qt examples (user program) on nto6.5?  There is nothing in the 'readme' describing the required
 build environment or caveats.
I was trying to build  'qt4/examples/declarative/toys/clocks' for example.
I have tried the instructions on self-hosted but to no avail.  The mentioned file 'build-hook' does not seem to be in
the archive.
Build targets for qmake
If your application is built with qmake, you can create QNX variants of the
application as follows (once the host and target packages are installed).
In the top-level application directory, create a Makefile with the following
text:
LIST=OS CPU VARIANT
MAKEFILE=GNUmakefile
include recurse.mk
##eof
Inside the same directory, create subdirectories called "nto-arm-le",
"nto-arm-le-v7", and "nto-x86-o", each containing a file called "GNUmakefile"
with this text:
ifndef QCONFIG
QCONFIG=qconfig.mk
endif
include $(QCONFIG)
include $(MKFILES_ROOT)/qmake-qt.mk
##eof
The application can be built for all QNX targets by running "make" at the top
level.  All standard qmake targets should work (e.g., "make install").
Optionally, a ksh script called "build-hook" can be placed at the top level; ...
Manual qmake invocation
qmake can also be executed manually; for example:
  "$QNX_HOST/usr/bin/qmake" -spec unsupported/qws/qnx-i386-g++
The following -spec options are available for QNX targets:
  unsupported/qws/qnx-arm-g++
  unsupported/qws/qnx-armv7-g++
