Yao Zhao(deleted)
Re: Error in building fuse
Yao Zhao(deleted)
08/27/2010 4:46 PM
post64891
> I am following the same method as mentioned in wiki. But i am getting error.
> make CPULIST=x86 install
> make -j 1 -Cnto-x86-o -fGNUmakefile install
> make[1]: Entering directory `/home/vibi/fuse/qnx/qfuse/trunk/lib/fuse/nto-x86-
> o'
> AR_HOST='ar -r' AS_HOST='gcc -c' CC_HOST='gcc -c -D__LINUX__ -D__X86__ -
> D__LITTLEENDIAN__' CL_HOST='gcc -D__LINUX__ -D__X86__ -D__LITTLEENDIAN__'
> CP_HOST='/opt/qnx641/host/linux/x86/usr/bin/qnx_cp -fpc ' DATE_HOST='/bin/date
> +%Y/%m/%d-%T-%Z' ECHO_HOST='/bin/echo' FL_HOST='/opt/qnx641/target/qnx6/usr/
> include/mk/flist-unix' GCC_VERSION='4.3.3' HOST_HOST='/bin/hostname'
> INSTALL_ROOT_AR='/home/vibi/fuse/qnx/qfuse/trunk/install/x86'
> INSTALL_ROOT_ARSHR='/home/vibi/fuse/qnx/qfuse/trunk/install/x86'
> INSTALL_ROOT_DLL='/home/vibi/fuse/qnx/qfuse/trunk/install/x86' INSTALL_ROOT_EX
> ='/home/vibi/fuse/qnx/qfuse/trunk/install/x86' INSTALL_ROOT_HDR='/home/vibi/
> fuse/qnx/qfuse/trunk/install/usr/include' INSTALL_ROOT_SO='/home/vibi/fuse/qnx
> /qfuse/trunk/install/x86' INSTALL_ROOT_linux='' INSTALL_ROOT_nto='/home/vibi/
> fuse/qnx/qfuse/trunk/install' KSH_HOST='/opt/qnx641/host/linux/x86/usr/bin/
> ksh' LD_HOST='gcc' LN_HOST='/bin/ln -sf ' MG_HOST='/bin/true' MKASMOFF_HOST='/
> opt/qnx641/host/linux/x86/usr/bin/mkasmoff ' MP_HOST='/opt/qnx641/target/qnx6/
> usr/include/mk/makepriv-unix' PB_HOST='/opt/qnx641/host/linux/x86/usr/bin/
> phabbind' PINFO_DATE='2010/08/20-20:12:54-IST' PINFO_HOST='QnX-vibi'
> PINFO_STATE='automation' PINFO_TAGID='9999' PINFO_USER='vibi' PWD_HOST='/bin/
> pwd' QNX_HOST='/opt/qnx641/host/linux/x86' RM_HOST='/bin/rm -f ' TOUCH_HOST='/
> bin/touch' UM_HOST='/opt/qnx641/host/linux/x86/usr/bin/usemsg' USER_HOST='/usr
> /bin/id -un' VERSION_REL='testbuilds' QNXVFLAGS='' QNXROOTINCS='-I/home/vibi/
> fuse/qnx/qfuse/trunk/install/usr/include -I/opt/qnx641/target/qnx6/usr/
> include' QNXROOTLIBS='-L/home/vibi/fuse/qnx/qfuse/trunk/install/x86/lib -L/
> home/vibi/fuse/qnx/qfuse/trunk/install/x86/usr/lib -L/opt/qnx641/target/qnx6/
> x86/lib -L/opt/qnx641/target/qnx6/x86/usr/lib' /opt/qnx641/host/linux/x86/usr/
> bin/ksh /opt/qnx641/target/qnx6/usr/include/mk/build-cfg install
> Building for target: nto-x86-o build:i386-pc-nto-qnx2.6.31-21-generic
> checking build system type... Invalid configuration `i386-pc-nto-qnx2.6.31-21-
> generic': machine `i386-pc-nto-qnx2.6.31-21' not recognized
> configure: error: /bin/sh ../config.sub i386-pc-nto-qnx2.6.31-21-generic
> failed
> /opt/qnx641/target/qnx6/usr/include/mk/build-cfg: error: configure failed
> make[1]: *** [install] Error 1
> make[1]: Leaving directory `/home/vibi/fuse/qnx/qfuse/trunk/lib/fuse/nto-x86-
> o'
> make: *** [install] Error 2
> Is this a known one ?
> Thanks & Regards
> vibi
I can't remember whether I support compiling on Linux host any more. At the beginning I use Linux host to port,
compiling and after some time when multiplatform is added, I may drop Linux host but I can't remember.
At least it can be compiled on QNX host.
thanks,
yao
