Forum Topic - Dev32.ser MEMIO: (8 Items)
Dev32.ser MEMIO
Hello QNX admins.
I want to use a PCIexpress serial card from AddiData to substitute PCI cards.
But the new cards only support Memory IO access and not a base address any more.
Therefore the producer extended an older Version of the Dev32.ser and we checked the usability with the new cards and it
 was working.
Can you check the attached Dev32.ser patch for the implementation in a newer Dev32.ser?
I dont want to loose the new feature of Interrupt share ability when I use the already developed update of an older
Dev32.ser.
BR, Klaus Pantleon
Attachment: Text dev.diff 21.34 KB
Re: Dev32.ser MEMIO
Hi Klaus,
Thanks for your input. I’ll look at this.
12 мая 2017 г., в 16:16, Klaus Pantleon <community-noreply@qnx.com> написал:
> Hello QNX admins.
it was working.
Dev32.ser.
> BR, Klaus Pantleon
> http://community.qnx.com/sf/go/post117733
> <dev.diff>
Re: Dev32.ser MEMIO
Hi Oleg, any success?
The vendor punishes me to take the PCIe Cards.
Re: Dev32.ser MEMIO
Hi Klaus,
Unfortunately, I can't find any MMIO based serial controllers, so I can't check the driver.
12 июля 2017 г., в 16:43:32, Klaus Pantleon <community-noreply@qnx.com> написал:
> http://community.qnx.com/sf/go/post117867
Re: Dev32.ser MEMIO
I can make the tests. If you have a Dev32.ser with the code extension from AddiData.
Of course I can send you one if that will help.
BR, Klaus
Re: Dev32.ser MEMIO
Hi Klaus,
Please find attached updated Dev32.ser. Keep in mind that this is an experimental software.
12 июля 2017 г., в 17:41:52, Klaus Pantleon <community-noreply@qnx.com> написал:
> BR, Klaus
> http://community.qnx.com/sf/go/post117869
Attachment: Text Dev32.ser_x86_170606.tar.gz 17.86 KB
Re: Dev32.ser MEMIO
Hi Klaus,
Did you try the driver that I've attached in my last message? How does it work on your hardware?
> AddiData.
> BR, Klaus
RE: Dev32.ser MEMIO
A colleague of mine made some tests.
Fred:
How was the test of the Dev.ser development from QNX for the PCIe of AddiData?
BR, Klaus
From: Oleg Bolshakov [mailto:community-noreply@qnx.com]
Sent: Tuesday, August 08, 2017 2:58 PM
To: general-qnx4
Subject: Re: Dev32.ser MEMIO
Hi Klaus,
> from AddiData.
> BR, Klaus
General
http://community.qnx.com/sf/go/post117945
