Forum Topic - Maximum devices in Dev?: (4 Items)
Hi:
Hopefully a simple question. What is the maximum number of devices that can be registered with Dev?
I see the default is 64 and the examples refer to 100, but whats the maximum?
Andy
Re: Maximum devices in Dev?
Hi Andy,
Dev does not have upper limit for maximum number of devices, so theoretically this value is limited by the available RAM
7 февр. 2017 г., в 3:17:47, Andy Rhind <community-noreply@qnx.com> написал:
> Hi:
> Thanks,
> Andy
> http://community.qnx.com/sf/go/post117397
Oleg:
Thank you for the reply.
I thought there wasn't an upper limit either. When I do "Dev -n200 &" All is ok, but "Dev -n300 &" appears to lock up
and the booting process stops.
Proc32 is 4.25R, Dev32 is 4.23G
Andy
Hi Andy,
I've just checked Dev and it seems to work fine on my system even with "Dev -n10000 &". I also use Proc32 4.25R and Dev32 4.23G. May be the problem is not in Dev. Do you really need 300 devices? Is it possible to run another Dev from command line after the system is booted?
9 февр. 2017 г., в 2:53:52, Andy Rhind <community-noreply@qnx.com> напи
сал:
> Oleg:
> I thought there wasn't an upper limit either. When I do "Dev -n200 &" All is ok, but "Dev -n300 &" appears to lock up and the booting process stops.
> Thanks,
> Andy
> http://community.qnx.com/sf/go/post117403
