Oleg Bolshakov
Query regarding porting from TCP/IP 4.25 to 5.10
Oleg Bolshakov
02/22/2012 4:02 AM
post91699
Hi Dave,
Yes, tcptk50.tar.F is matching the TCP/IP 5.10 run-time.
To localize your issue, please, build demo projects from tcptk50.tar.F bundle.
They are located at /usr/tcptk/5.0/usr/demo/src/socket after installation. In
case the issue occurs, post here your build log.
> Can anyone advise me how to fix this issue?
> I'm attempting to move a legacy project from tcp 4.25 to the latest 5.10.
> The headers have changed slightly but apart from that the socket3r.lib is
available with
> the new tcprt5.0 installed linked to /usr/lib /usr/watcom/10.6/usr/lib.
> The watcom compiler fails to pick up the socket_, setsocketopt_, htons_,
bind_ etc.
> The previously working build has no explicit socket parameter and it appears
the
> the library path was sufficient to satisfy the linker.
> Am I correct in saying that tcptk50.tar.F matches the runtime from the
latest install
> disk?
> Thanks in advance for any clues.
> http://community.qnx.com/sf/go/post91693
Dave Ferris(deleted)
Re: Query regarding porting from TCP/IP 4.25 to 5.10
02/22/2012 12:11 PM
post91712
To answer my own question, incase anyone else wants to know.
The link failed as watcom was unable to select the library automatically.
Looking at socket.h from the older 4.25 installation and the new one shows this pragma block..
#if defined __SW_3R
# pragma library (socket3r)
# elif defined __SW_3S
# pragma library (socket3s)
#elif defined __SMALL__
# pragma library (sockets)
#elif defined __COMPACT__
# pragma library (socketc)
#elif defined __MEDIUM__
# pragma library (socketm)
#elif defined __LARGE__
# pragma library (socketl)
#endif
Adding this back to the later socket.h cured my link issue.
Perhaps there is a better solution, but it works.
Dave.
