Forum Topic - PCIe Dev32.ser problem: (2 Items)
Hello QNX masters,
I have a problem in the startup of the Dev32.ser.
Up to now I was using a PCI 4xserial card and everything was fine.
Now I'm testing the PCIe card from the same vendor and dont know how to start the Dev32.ser.
There is no output in show_pci for an IO range. Only information for Mem.
The same info I get booting linux and using lspci. But in Linux there is the standard serial driver module "serial" used
Is there a possibility to use the Mem info in the start of the Dev32.ser?
br,
Klaus
Hi Klaus,
Unfortunately, the Dev32.ser can't access to registers via memory. It uses I/O
ports only.
> Hello QNX masters,
standard serial driver module "serial" used.
> br,
> Klaus
> http://community.qnx.com/sf/go/post89683
