Forum Topic - Microchip TSHARC-10 (Octopus) USB touchscreen controller: (5 Items)
Is there a device driver available for this controller?  The VID is 07dd (Hampshire Company) and the DID is 0001.
Rob
Re: Microchip TSHARC-10 (Octopus) USB touchscreen controller
How about an Input and USB DDK (Official or not)?  I seem to recall that Erick Muis had an "Unofficial" Input DDK but I
am not sure if it works with a USB device.  This particular USB touchscreen controller is also HID-compliant but it
won't calibrate properly via the calib program.
Rob
>  Muis had an "Unofficial" Input DDK but I am not sure if it works with a USB
> it won't calibrate properly via the calib program.
> Rob
Hi Rob,
The last update I did to the driver should support HID complaint screens.  What happens when you run:
devu-touch &
...wait a moment for the driver to start
Input generic fd -d/dev/usbtouch0 &
Does anything happen? if so, what?  Could you post the verbose output from Input
The DDK does not have any usb framework in place, however what you can do is if the devu-touch driver does not work, is
grab the USB DDK and then write a quick driver that takes the data and converts it to the generic protocol format (as
seen below).  The Input driver can then attach to it and there will be no need to change the Input driver itself.
Please let me know if this helps or not.
Best regards,
Erick
  Generic interface for non serial/ps2 touchscreens
  This is the generic protocol that is expected.  The external driver
  must use the following protocol in order for the generic driver to
  function correctly.  The number of bits is not critical.  This can
  be changed via the command line option -B to specify the number of
  bits for each coordinate.  The default is 14.  If you do not use
  all 14, make certain that the values not used are 0.
                  MSB             Bits               LSB
  Data Sequence    7    6    5    4    3    2    1    0
  S-Byte 1         1    S6   XXXXXXXXX Reserved XXXXXXXX
  X-Byte 2         0    X6   X5   X4   X3   X2   X1   X0
  x-Byte 3         0    X13  X12  X11  X10  X9   X8   X7
  Y-Byte 4         0    Y6   Y5   Y4   Y3   Y2   Y1   Y0
  y-Byte 5         0    Y13  Y12  Y11  Y10  Y9   Y8   Y7
  S0-S5     Reserved
  S6        Proximity        1 = Touchscreen is being touched (a
                             touchdown or a continued touch).
                             0 = Touchscreen is not being touched (a
                             touch liftoff or inactive).
  S7        Packet           Always 1.
            synchronization
Erick:
     Thanks for the response.  I would try that but I don't have the devu-touch program?  Where do I find it?  FYI: I
installed this node using the 2010 Experimental Product Suite CD.
Rob
Hi Rob,
Sorry, my memory appears to be getting dusty.   The driver is not devu-touch, rather
/bin/devu-elo
/bin/devu-microtouch
/bin/devu-touchintl
/bin/devu-egalax
So that really won't help you much, unless the TSHARC-10 protocol is similar to one of the existing drivers and you can
use that.
Easiest thing to do is try starting the drivers (try one at a time) and pass in the vendor and device ID to the driver
(run "use {drivername}") to see the usage.  Then try that and see if that works or not.  As I recall the TSHARC uses a
similar protocol to one of those controllers, I just can't recall which at this time.  If I can find some spare time I
can try to look it up, just been rather busy lately.
Best regards,
Erick
> Erick:
> touch program?  Where do I find it?  FYI: I installed this node using the 2010
> Rob
