Sebastián Cerella(deleted)
Video problem with Advantech PPC-154T
01/18/2011 1:06 PM
post82456
Hi, I have a PPC-154T with an Intel 845GV chipset video and a touch screen connected to the USB port. The video driver
is not detected by the crttrap comand. I believe, the driver should be the Pg.i830 but I can´t do it work. Doing so
with the Pg.flatdc32 but is very slow to refresh.
This is detected by the latest version of crttrap (not work):
vesabios.ms -i0x12;Pg.vga4 -HNqnx/crt -g640x480x4 - A0xA0000,0x10000 -WB80;#640,480,4,100,1D,vga4 - VGA 16 color
That worked, but slow:
Hydra.ms -S -i0x4118 -s0x0000,0x0010 -r;Pg.flatdc32 -HC0x00000010 -PX -HNqnx/crt -g1024x768x32 -A0xE0000000,0x7D0000 -
WB4096;#1024,768,32,100,1,flatdc32- VGA hi-color
This should work, I think:
Null.ms;Pg.i830 -g1024x768x16 -d0x8086,0x2562 -I0 -HNqnx/crt;#1024,768,16,200,0CBDr,i830 - Intel 82830/82845/82852/82855
/82865
show_pci:
Class = Display (VGA)
Vendor ID = 8086h, INTEL CORPORATION
Device ID = 2562h,
PCI index = 0h
MEM @ e0000000h MEM @ ec100000h
PCI Int Pin = INT A
Interrupt line = 10
can you help me, please?
thanks.
Sebastián.
Oleg Bolshakov
Re: Video problem with Advantech PPC-154T
Oleg Bolshakov
01/20/2011 2:04 PM
post82516
Hi Sebastián,
Do you have installed latest Pg.i830, crttrap and crttrap.list?
Intel 845GV (0x8086:0x2562) controller is supported by the Pg.i830. But as
far as I know the PPC-154T is very specific panel PC, so it can be
incompatible with the driver.
> screen connected to the USB port. The video driver is not detected by
> can´t do it work. Doing so with the Pg.flatdc32 but is very slow to
> refresh. This is detected by the latest version of crttrap (not work):
> -WB80;#640,480,4,100,1D,vga4 - VGA 16 color That worked, but slow:
> -WB4096;#1024,768,32,100,1,flatdc32- VGA hi-color This should work, I
> think:
> 82830/82845/82852/82855/82865 show_pci:
> Device ID = 2562h,
> PCI index = 0h
> PCI Int Pin = INT A
> Interrupt line = 10
> thanks.
> Sebastián.
> http://community.qnx.com/sf/go/post82456
01/21/2011 5:25 AM
post82525
Oleg, thanks for your answer. The PC was reinstated with QNX 4 Product Suite CD 2010 EXPERIMENTAL thus I have all the
latest versions.
The video does not matter at this time. Does not recognize the usb touch screen.
# usb
USB 3 (UHCI) v1.10, v1.01 DDK, v1.01 HCD
Device Address : 1
Vendor : 0x1204 (DIALOGUE INC)
Product : 0x9998 (PenMount USB)
Class : 0x00 (Independant per interface)
I tested with devu-touchintl, devu-elo, devu-microtouch, devu-egalax but never the file descriptor is created. Only is
created for devu-mouse.
Any suggestions?
Thanks in advance.
Sebastián.
Oleg Bolshakov
Oleg Bolshakov
01/21/2011 8:10 AM
post82534
Hi Sebastián,
I guess that PenMount protocol is not supported by QNX4 drivers. But you
can try to start drivers with "-x 0x1204" option to check this.
> Suite CD 2010 EXPERIMENTAL thus I have all the latest versions. The
> screen. # usb
> Device Address : 1
> but never the file descriptor is created. Only is created for
> devu-mouse. Any suggestions?
> Thanks in advance.
> Sebastián.
> http://community.qnx.com/sf/go/post82525
01/21/2011 2:40 PM
post82551
With the vendor the /dev/ appears but I can not calibrate with calib.
Is it possible to get the source code of some of the drivers?
Oleg Bolshakov
Oleg Bolshakov
01/25/2011 8:24 AM
post82613
Hi Sebastián,
It seems that your PenMount controller isn't supported by the QNX 4.25. Do
you test how it works in QNX 6.5?
> Thanks
> http://community.qnx.com/sf/go/post82551
01/25/2011 8:42 AM
post82616
Yes, with QNX6.5 is running devi-hid and work perfectly (I did a quickly tested.).
Thanks.
Sebastián
Pavel Kozlov(deleted)
02/01/2011 5:06 AM
post82809
Hi Sebastián,
Please describe what happens with cursor when you run calib utility. Cursor movers chaotically or doesn't move at all?
Have you tried another calibration utility acalib?
Please provide sin ar, sin ver output (before you run calib).
Also it would be helpful if you provide pidin output from QNX 6.5:
# pidin mem
Pavel
> Thanks.
> Sebastián
> http://community.qnx.com/sf/go/post82616
