Itachi Senpai
QNX 4.25 and Intel GMA3000:
Itachi Senpai
12/01/2010 11:31 PM
post76776
I would like to know whether we have such driver or not?
BR
Anh
Oleg Bolshakov
Re: QNX 4.25 and Intel GMA3000:
Oleg Bolshakov
12/02/2010 3:45 AM
post76780
Hi Itachi,
If you're asking for Photon graphics driver, then Pg.i830 has support of
945G (0x8086:0x2972) and Q965/Q963 (0x8086:0x2992) devices. As far as I
know 945G and Q965 are both based on the GMA 3000 chipset.
You can download the latest Pg.i830 driver from Software Updates 2010
page:
http://community.qnx.com/sf/wiki/do/viewPage/projects.qnx4/wiki/SoftwareUpdates2010
If I don't answer your question then, please, clarify your question and
specify PCI device IDs of interested controllers.
> BR
> Anh
> http://community.qnx.com/sf/go/post76776
Itachi Senpai
Itachi Senpai
12/02/2010 9:58 PM
post77014
At first thanks for your reply. I really appreciate that.
This is the description of my Comp:
IBM - Lenovo ThinkCentre M55 (9389-AF5) (Intel Pentium 4 631 3.0Ghz, 512MB RAM, 80GB HDD, VGA Intel GMA 3000, PC DOS,
Monitor 15 inch CRT) with Chipset Mainboard : Intel 946GZ.
I downloaded I830 and follow installation instruction at :
http://community.qnx.com/sf/wiki/do/viewPage/projects.qnx4/wiki/InstallationNotesForGraphicsDrivers
when i try to start photon, it has problem like below
//86/qnx4/graphics/drivers/vesabios.ms terminated (SIGSEGV) at 0005:0000DC81.
couldn't open ////.photon/pwm/pwm.cfg for read
and Photon can't start.
Can you please help ?
Thanks in advance
Br,
Anh
Oleg Bolshakov
Oleg Bolshakov
12/03/2010 7:29 AM
post77041
Hi Itachi,
To be clear, please, post here output of:
# show_pci -vv > show_pci.txt
# sin ver > sin_ver.txt
# sin ar > sin_ar.txt
# sin ir > sin_ir.txt
Have you installed the QNX from the QNX4 Update CD 2009? Also check that
you've correctly executed all following steps:
1. Download and install latest Pg.i830 driver.
2. Download and install latest crttrap.list file.
3. Launch following commands:
# crttrap clear
# crttrap trap
4. Launch the Photon:
# ph
Please, post here /etc/config/trap/crt.<node> file.
> 512MB RAM, 80GB HDD, VGA Intel GMA 3000, PC DOS, Monitor 15 inch CRT)
> 0005:0000DC81.
> 0005:0000DC81. couldn't open ////.photon/pwm/pwm.cfg for read
> Thanks in advance
> Br,
> Anh
> http://community.qnx.com/sf/go/post77014
Itachi Senpai
Itachi Senpai
12/07/2010 1:14 AM
post77563
Hi Oleg,
This OS is used to test, so the environment should be the same so update to QNX CD 2009 is not suitable.
This is the log for everything you requested, pls check the attached file and provide some comment if any.
BR,
Itachi
> Hi Itachi,
> # crttrap clear
> # crttrap trap
> # ph
> Respectfully,
> Oleg
> > 0005:0000DC81.
> > Thanks in advance
> > Br,
> > Anh
> > General
Oleg Bolshakov
Oleg Bolshakov
12/07/2010 7:05 AM
post77575
Hi Itachi,
The Intel 946GZ (Device ID 0x2972) isn't supported by the Pg.i830. But
this may be changed in one of future updates.
> Hi Oleg,
> BR,
> Itachi
> > Hi Itachi,
> > that you've correctly executed all following steps:
> > # crttrap clear
> > # crttrap trap
> > # ph
> > > 3.0Ghz, 512MB RAM, 80GB HDD, VGA Intel GMA 3000, PC DOS, Monitor
> > > tall ationNotesForGraphicsDrivers
> > > 0005:0000DC81.
> > > Thanks in advance
> > > Br,
> > > Anh
> > > General
> http://community.qnx.com/sf/go/post77563
Itachi Senpai
Itachi Senpai
12/07/2010 9:59 AM
post77614
Hi Oleg,
Hopefully it will be updated. Thanks very much Oleg.
BRs,
Itachi
> Hi Itachi,
> Respectfully,
> Oleg
> > Hi Oleg,
> > BR,
> > Itachi
> > > Hi Itachi,
> > > # crttrap clear
> > > # crttrap trap
> > > # ph
> > > > 0005:0000DC81.
> > > > Thanks in advance
> > > > Br,
> > > > Anh
> > > > General
> > General
Oleg Bolshakov
Oleg Bolshakov
12/13/2010 12:06 PM
post78452
Hi Itachi,
I've attached both updated Pg.i830 and crttrap.list. I'll have updated the Software Updates 2010 page if you confirm
what that driver works fine.
> Hi Oleg,
> BRs,
> Itachi
> > Hi Itachi,
> > Respectfully,
> > Oleg
> > > Hi Oleg,
> > > BR,
> > > Itachi
> > > > Hi Itachi,
> > > > # crttrap clear
> > > > # crttrap trap
> > > > # ph
> > > > > 0005:0000DC81.
> > > > > Thanks in advance
> > > > > Br,
> > > > > Anh
> > > > > General
> > > General
Oleg Bolshakov
Oleg Bolshakov
12/13/2010 12:07 PM
post78454
Itachi,
The crttrap.list is attached.
Itachi Senpai
Itachi Senpai
12/14/2010 9:57 PM
post78776
Oleg Bolshakov
Oleg Bolshakov
12/15/2010 12:41 AM
post78786
Hi Itachi,
Quite how doesn't work the driver? Please, post here your new
/etc/config/trap/crt.<NODE> file.
> Hi Oleg,
> The new driver doesn't work.
> I follow the steps in this
> do i need doing anything else ?
> http://community.qnx.com/sf/go/post78776
