Theuns Steyn
08/16/2010 5:15 AM
post63044
> Hello,
> I have just tested the new version of Pg.i830 (August 06th) on a IEI ECW-281 (
> Atom N270 + i945GSE). In this configuration the driver still does not work.
> 'crttrap' hangs after it has printed the line "/qnx4/graphics/trappers/Pg.i830
> -d0x8086,0x27ae -T". Nevertheless a new trap file 'crt.1' was written. When I
> start Photon it results in a black screen.
> Attached you will find a file with the output of 'show_pci' for ECW-281.
> Best regards
> Hans-Peter
Hello Hans-Peter
We had the exact same problem, also with iEi hardware (WAFER-945GSE3).
What we did to solve the problem was to change The northbridge chipset settings where the boot display device was set to
Auto. After changing it to CRT, all the problems were solved.
Another thing we did was to modify the crt.1 file so that the first line of the entries was the same as the safe.1 file
(safe mode graphics). This will get you into photon. You can also skip this step and modify the crt.1 file so that the
Pg.i830 driver initialisation is the first line in the crt.1 file.
Kind regards,
Theuns
