Forum Topic - second Fsys.atapi on same int : (5 Items)
I'm actually trying to bring QNX4 on a Dell D6510 because these Laptop is an actual one with pccard port. Ans I need the
 pccard port to write on PCMCIA flash drives.
Therefore I start a second Fsys.atapi with the settings I get from pc-pin and the device will be atached. But as soon as
 I want to access the new device (e.g. fdisk /dev/pcmcia0) the Fsys.atapi from the real harddisk is consuming the most
CPU usage. The command itself will work but only very very slow reaction.
Both Fsys.atapi are running purely on the same interrupt  and I have no chance to change it.
Is there a possibility to tell the Fsys.atapi that he should waste no time if there is an interrupt coming, but this int
 is not for him? There is another Fsys.atapi running for the accessed device.
The rest of the laptop is usable with QNX4 (net, graphic, usb, ...).
Re: second Fsys.atapi on same int
Hi Klaus,
Please provide us a bit more technical information:
sin ar
sin ver
sin ti
sin ir
sin pr
show_pci -vvv
pc-pin
Also try to start single Fsys.atapi driver for all controllers.
> Hello,
> is an actual one with pccard port. Ans I need the pccard port to write
> pc-pin and the device will be atached. But as soon as I want to access
> harddisk is consuming the most CPU usage. The command itself will work
> but only very very slow reaction. Both Fsys.atapi are running purely
> on the same interrupt  and I have no chance to change it. Is there a
> there is an interrupt coming, but this int is not for him? There is
> http://community.qnx.com/sf/go/post58667
Hi Oleg,
I made a test to extract the problem as most clear as I can:
1) Boot over the network
2) start Fsys.atapi for cd
3) start Fsys.atapi for hd
4) checked speed for cd and hd
5) stopped Fsys.atapi
6) Start Fsys.atapi for cd and hd
7) checke speed for cd and hd
This test I made for the Dell and for a VMWare and attached the terminal aoutput in the following. Also I made the "sin
ar" for both environment before starting the testprocedure. You will see that theses effect is not reproducable in
VMWare. Please tell me at wht time in teh testprocedure you want the "sin ??" calls.
sin ar for Dell:
  PID USER NAME    ARGUMENTS
    1 System       Proc32 -l 179 -p2000 -P26
    2 System       Slib32
    4 System       Net -n500 -m 2 1 000C29 1EEDBD
    5 System       Net.e1000 -I0 -l1
    7 System       Not available.
  491 System       Pipe
  509 System       Dev -n 100
  527 System       Dev.ansi -Q -n 4
  626 System       tinit -t /dev/con1 /dev/con2 /dev/con3 /dev/con4 /dev/config
  636 System       /bin/nameloc
  639 System       /bin/nameloc
 1306 System       /bin/login -p
 1321 System       /bin/login -p
 1355 System       /bin/login -p
 1381 System       /bin/login -p
 5051 root         -sh
 5781 root         sin ar
sin ar for VMWare:
    1 System       Proc32 -l 182 -p2000 -P26
    2 System       Slib32
    5 System       Net.ether2100 -I0 -l1
  489 System       Pipe
  507 System       Dev -n 100
  525 System       Dev.ansi -Q -n 4
  541 System       Dev.ser -b38400 -t14
  636 System       tinit -t /dev/con1 /dev/con2 /dev/con3 /dev/con4 /dev/config
  646 System       /bin/nameloc
  649 System       /bin/nameloc
 1308 System       /bin/login -p
 1333 System       /bin/login -p
 1357 System       /bin/login -p
 1390 System       /bin/login -p
 2335 root         -sh
 2826 root         sin ar
Testprocedure Dell:
(root)//179/root>Fsys &
%1 +  7359 Running              Fsys
(root)//179/root>
(root)//179/root>Fsys.atapi fsys -Ncd -n0=cd atapi ioport=0x7090 &
%2 +  7582 Running              Fsys.atapi fsys -Ncd -n0=cd atapi ioport=0x7090
(root)//179/root>Path=0 - Generic IDE
 target=0 lun=0 CD-ROM(5) - MATSHITA DVD+-RW UJ892    Rev: 1.04
(root)//179/root>Fsys.atapi fsys -Nhd -n0=hd atapi ioport=0x70f0,irq=10 &
%3 +  7957 Running              Fsys.atapi fsys -Nhd -n0=hd atapi ioport=0x70f0
 target=0 lun=0 Direct-Access(0) -          WDC WD2500BEKT-7 Rev: 01.0
(root)//179/root>cp -V /dev/cd0 /dev/null
cp: Copying /dev/cd0 to /dev/null
 20.70% (36160/174622 kbytes, 904 kb/s)
(root)//179/root>cp -V /dev/hd0 /dev/null
cp: Copying /dev/hd0 to /dev/null
 00.00% (6048/24419858 kbytes, 1745 kb/s)
(root)//179/root>rm /dev/cd0 /dev/hd0
%2 -  7582 Done                 Fsys.atapi fsys -Ncd -n0=cd atapi ioport=0x7090
%3    7957 Done                 Fsys.atapi fsys -Nhd -n0=hd atapi ioport=0x70f0
(root)//179/root>Fsys.atapi atapi ioport=0x70f0,irq=10 atapi ioport=0x7090 &
%2 + 12229 Running              Fsys.atapi atapi ioport=0x70f0,irq=10 atapi iop
Path=1 - Generic IDE
 20.88% (36464/174622 kbytes, 1469 kb/s)
 00.00% (6784/24419858 kbytes, 13789 kb/s)
(root)//179/root>
Tesprocedure VMWare:
(root)//182/root>
(root)//182/root>Fsys.atapi fsys -Ncd -n0=cd atapi ioport=0x170,irq=15 &
%2 + 11760 Running              Fsys.atapi fsys -Ncd -n0=cd...
Hi Klaus,
Sorry for delay with answer. I need output of
sin ar
sin ver
sin ti
sin ir
sin pr
show_pci -vvv
pc-pin
when your system works slow. Also I can't find the Dell D6510 specification,
so post it (or link to it) here. May be using a USB stick instead of
PCMCIA flash drive is a better idea.
> Hi Oleg,
> terminal aoutput in the following. Also I made the "sin ar" for both
> theses effect is not reproducable in VMWare. Please tell me at wht
> sin ar for Dell:
>     2 System       Slib32
>   491 System       Pipe
> /dev/config 636 System       /bin/nameloc
>  5051 root         -sh
>  5781 root         sin ar
> sin ar for VMWare:
>     2 System       Slib32
>   489 System       Pipe
> /dev/config 646 System       /bin/nameloc
>  2335 root         -sh
>  2826 root         sin ar
> Testprocedure Dell:
> (root)//179/root>
Ncd -n0=cd atapi
> ioport=0x7090 (root)//179/root>Path=0 - Generic IDE
> & %3 +  7957 Running              Fsys.atapi fsys -Nhd -n0=hd atapi
> ioport=0x70f0 (root)//179/root>Path=0 - Generic IDE
> ioport=0x7090 %3    7957 Done                 Fsys.atapi fsys -Nhd
> -n0=hd atapi ioport=0x70f0 (root)//179/root>Fsys.atapi atapi
> ioport=0x70f0,irq=10 atapi ioport=0x7090 & %2 + 12229 Running        ...
RE: second Fsys.atapi on same int
Hi Oleg,
sorry but I dont have the hardware any more on my desktop.
As soon as I have the next Dell 6510 I will give you the "sin ??" info.
The proposal with an USB2PCMCIA adapter I already tested and it is much much faster.
But I want to offer the service persons of my company a solution without any add on hardware.
These add on hardware I cannot control. The vandor and type of laptop is good to control.
Freundliche Grüße / Best regards
Klaus Pantleon
Softwarestandardisierung, Hardwarestandardisierung, Fernwartungslösungen
_________________________________________________
Voith Paper Automation GmbH & Co. KG
- prf
St. Pöltener Straße 43
89522 Heidenheim, Germany
Tel  +49 7321 37 2137
Fax  +49 7321 37 6109
Mobile  +49 172 7394158
Klaus.Pantleon@Voith.com
http://www.voithpaper.com
http://www.fieldinstruments.voithpaper.com
Handelsregister Ulm, HRA 661188
Sitz der Gesellschaft: Heidenheim
Geschäftsführung:
Dr. Antti Kaunonen (Vorsitzender), Ingolf Cedra, Alexander Kienle
Persönlich haftende Gesellschafterin: Voith Paper Automation Verwaltungs GmbH, Reg. Gericht Ulm, HRB 661292
From: Oleg Bolshakov [mailto:community-noreply@qnx.com]
Sent: Monday, August 02, 2010 12:37 PM
To: general-qnx4
Subject: Re: second Fsys.atapi on same int
Hi Klaus,
sin ar
sin ver
sin ti
sin ir
sin pr
show_pci -vvv
pc-pin
when your system works slow. Also I can't find the Dell D6510 specification, so post it (or link to it) here. May be using a USB stick instead of PCMCIA flash drive is a better idea.
> Hi Oleg,
> sin ar for Dell:
>     2 System       Slib32
>   491 System       Pipe
>  5051 root         -sh
>  5781 root         sin ar
> sin ar for VMWare:
>     2 System       Slib32
>   489 System       Pipe
>  2335 root         -sh
>  2826...
