Forum Topic - Net.e1000: (12 Items)
Net.e1000
I am using an Intel PRO 1000 PT Desktop Adapter network card with the QNX Product Suite 2009.
I had been using the card under QNX 4.25G with the Net.i82540 driver with no problem. Although we were using a newer
i82540 driver that QNX fixed for the indicated card.
Under the QNX Product Suite 2009 nettrap start gives me the following messages:
No devices found
loc_e1000 failed
Net:nm_load(): brg_tbl_autoload() failed
For a work around we kept the version of Net.i82540 and can use that with the new Product suite 2009 and it works nicely
 However we would welcome a fix for this issue.
It appears as though the latest changes to Net.i82540 did not get incorporated into Net.e1000.
- Much thanks,
   Kevin
Re: Net.e1000
Hi Kevin,
Please, post output of show_pci utility.
>  with no problem. Although we were using a newer i82540 driver that QNX
>  messages: No devices found
> loc_e1000 failed
>  with the new Product suite 2009 and it works nicely.
> - Much thanks,
>    Kevin
> http://community.qnx.com/sf/go/post42794
Re: Net.e1000
Hi Oleg:
 Please find attached the show_pci output
- Kevin
Attachment: Text showpci 1.1 KB
Re: Net.e1000
Hi Kevin,
Please post here output of:
# nettrap query -v
and try to start Net.e1000 driver manually:
# slay Net
# Net &
# Net.e1000 &
What is your result?
> Hi Oleg:
> - Kevin
> http://community.qnx.com/sf/go/post42962
Re: Net.e1000
Hi Oleg:
 The output of the command nettrap query -v
 was as follows:
   Net.e1000  -I0 -l1 &
   netmap -f
 When I ran the following commands:
 slay Net
 Net &
 Net.e1000 &
 the ouput was as follows:
 No devices found
 loc_e1000 failed
 when the Enter key was pressed the following was displayed:
 %2   +    59   Done (1)   Net.e1000
- Kevin
Re: Net.e1000
Hi Kevin,
Please repeat this test and specify a PCI device ID of your network
controller:
slay Net
Net &
Net.e1000 -d 0x10b9 &
> Hi Oleg:
>  was as follows:
>    Net.e1000  -I0 -l1 &
>    netmap -f
>  slay Net
>  Net &
>  Net.e1000 &
>  No devices found
>  loc_e1000 failed
> - Kevin
> http://community.qnx.com/sf/go/post43061
Re: Net.e1000
Hi Oleg:
 I tried the Net.e1000 -d 0x10b9 &
 and I got the same results as before:
 No devices found
 loc_e1000 failed
 - Kevin
Re: Net.e1000
Hi Kevin,
Sorry, I've forgot to attach the file. ;-}
> Hi Oleg:
>  No devices found
>  loc_e1000 failed
>  - Kevin
> http://community.qnx.com/sf/go/post43213
Attachment: Text e1000_loc 8.23 KB
Re: Net.e1000
Hi Kevin,
Hmmm, it's really strange... We've prepared the test utility for your
case. Please run it as specified below an post here its output:
# e1000_loc -v
# e1000_loc -I1
# e1000_loc -d 10B9 -v
# e1000_loc -d 10B9 -I1
Also we need more PCI information. Please provide us output of:
# show_pci -vv
> Hi Oleg:
>  No devices found
>  loc_e1000 failed
>  - Kevin
Re: Net.e1000
Hi Oleg:
 I've attached the output of the e1000_loc routine as you requested.
 To run the utility I went into the alternate boot
 and started Net &
 Then I ran the utility as you requested.
 I have also attached the output of the show_pci -vv.
 I looked at the output of the e1000_loc and it seems to recognize the card.
 Yet when I run the Net.e1000 it gives me the same No devices found
 loc_e1000 failed.
 Is the loc_e1000 utility that Net.e1000 uses different from the e1000_loc that you sent me ????
 - Kevin
Attachment: Text e1000_loc-diags 35.23 KB
Re: Net.e1000
Hi Kevin,
The loc_e1000() functions are equal in both Net.e1000 driver and sent test
utility. This error occurs only if specific HW is not found at PCI bus
(0x8086:0x10B9 in your case). I don't know how to explain your issue
without HW. So you can use Net.i82540 driver.
> Hi Oleg:
>  and started Net &
>  card.
>  loc_e1000 failed.
>  - Kevin
> http://community.qnx.com/sf/go/post43460
Re: Net.e1000
Hi Oleg:
 Thanks for your help. For now we will use the old Net.i82540 for this
card.
 - Kevin
Oleg Bolshakov <community-noreply@qnx.com>
12/14/2009 07:43 AM
Please respond to
post43765@community.qnx.com
To
general-qnx4 <post43765@community.qnx.com>
cc
Subject
Re: Net.e1000
Hi Kevin,
> Hi Oleg:
>  and started Net &
>  card.
>  loc_e1000 failed.
>  - Kevin
General
http://community.qnx.com/sf/go/post43765
