Communicating across VLAN Interfaces
08/20/2008 10:53 PM
post12157
I am having problem with communicating through VLAN interfaces. Here's the behavior.
I have one physical interface with no IP address assigned to it and I create 3 VLAN interfaces with id's 512,768 and
1024. Then I assign IP address to vlan interface with vlanid 1024. I do this setup on two system connected within the
same network. Then, I try pinging from one node to the other via the VLAN interface. The ping doesnt succeed. I ran
tcpdump on the two nodes and I see that the arp message arrives on the other node but io-pkt does not respond to the ARP
message.
But, if setup an IP address on the physical (parent) interface and then perform the same set of actions, the ping works!
Is this a known problem? I am using revision 400 of trunk.
Santosh
RE: Communicating across VLAN Interfaces
08/20/2008 11:17 PM
post12158
I think the minimum requirement is that the parent is IFF_UP
which also happens when you assign it an addr:
# ifconfig <parent> up
From: Santosh Kumar [mailto:community-noreply@qnx.com]
Sent: Wed 8/20/2008 10:53 PM
To: technology-networking
Subject: Communicating across VLAN Interfaces
message.
Santosh
Technology
http://community.qnx.com/sf/go/post12157
Re: RE: Communicating across VLAN Interfaces
08/20/2008 11:23 PM
post12159
Hi Sean,
I tried doing a ifconfig up and then set vlan. Same result. Actually without IFF_UP we cant even send packets out of the
interface.
-Santosh
> -seanb
> behavior.
> VLAN interfaces with id's 512,768 and 1024. Then I assign IP address to vlan
> interface. The ping doesnt succeed. I ran tcpdump on the two nodes and I see
> the ARP message.
> perform the same set of actions, the ping works!!
> Thanks,
> Santosh
> Technology
RE: RE: Communicating across VLAN Interfaces
08/21/2008 2:05 PM
post12209
Hi Santosh:
What commands do you use to create and set up the vlan interfaces?
What does ifconfig report before and after you assign the parent IP
address that makes things work?
Robert.
Sent: Wednesday, August 20, 2008 11:24 PM
Subject: Re: RE: Communicating across VLAN Interfaces
Hi Sean,
without IFF_UP we cant even send packets out of the interface.
-Santosh
> -seanb
the
> behavior.
create 3
to vlan
within the
VLAN
I see
respond to
> the ARP message.
then
> Thanks,
> Santosh
> Technology
Technology
http://community.qnx.com/sf/go/post12159
Re: RE: RE: Communicating across VLAN Interfaces
08/21/2008 2:48 PM
post12216
I program it. Here's the code:
status_t
ether_add_vlan( const char *parentif, const char *vlanname, uint16_t vlan_id)
struct vlanreq vlan_data;
struct ifreq ifr;
status_t ret;
if ( _eth_fd < 0 ) {
if ( ( _eth_fd = socket( AF_INET, SOCK_DGRAM, 0 ) ) < 0 ) {
return ( errno );
if (!parentif || !vlanname || (strlen(parentif) > IFNAMSIZ) || (strlen(vlanname) >IFNAMSIZ))
return(TN_SYS_ERROR_INVALID_ARG);
memset(&ifr,0,sizeof(struct ifreq));
strcpy(ifr.ifr_name, vlanname);
ret=ioctl(_eth_fd, SIOCIFCREATE, &ifr);
if (ret!=SUCCESS) {
if (errno!=EEXIST)
return(errno);
else
return(SUCCESS);
memset( &vlan_data, 0, sizeof( struct vlanreq ) );
strcpy(ifr.ifr_name,vlanname);
ifr.ifr_ifru.ifru_addr.sa_family=AF_INET;
ifr.ifr_ifru.ifru_data=(object_t)&vlan_data;
ret=ioctl_socket(_eth_fd, SIOCGETVLAN, &ifr);
if (ret!=SUCCESS)
return(errno);
vlan_data.vlr_tag = vlan_id;
ret=ioctl_socket( _eth_fd, SIOCSETVLAN, &ifr );
if (ret!=SUCCESS)
return(errno);
if (ret!=SUCCESS)
return(errno);
strcpy(vlan_data.vlr_parent,parentif);
return(ioctl_socket( _eth_fd, SIOCSETVLAN, &ifr ));
status_t
ether_del_vlan( const char *vlanname)
struct ifreq ifr;
status_t ret;
return ( errno );
if (!vlanname || (strlen(vlanname) > IFNAMSIZ))
ret=ioctl_socket( _eth_fd, SIOCGETVLAN, &ifr );
if (ret!=SUCCESS)
return(errno);
printf("vlan_parent=%s,vlanid=%d\n",vlan_data.vlr_parent,vlan_data.vlr_tag);
vlan_data.vlr_parent[0]='\0';
vlan_data.vlr_tag = 0;
if (ret!=SUCCESS)
return(ret);
ifr.ifr_ifru.ifru_data=NULL;
return(ioctl(_eth_fd, SIOCIFDESTROY, &ifr));
After the code runs, the out put of ifconfig contains (I create multiple):
# ifconfig
en0: flags=8043<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
address: 00:1f:aa:ff:ff:d0
inet 10.7.0.40 netmask 0xffffff00 broadcast 10.7.0.255
en1: flags=8043<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
address: 00:1f:aa:ff:ff:d1
inet 10.7.0.41 netmask 0xffffff00 broadcast 10.7.0.255
en2: flags=8002<BROADCAST,MULTICAST> mtu 1500
address: 00:1f:aa:ff:ff:d2
en3: flags=802<BROADCAST,SIMPLEX> mtu 1500
address: 00:1f:aa:ff:ff:d3
en4: flags=802<BROADCAST,SIMPLEX> mtu 1500
address: 00:1f:aa:ff:ff:d4
en5: flags=802<BROADCAST,SIMPLEX> mtu 1500
address: 00:1f:aa:ff:ff:d5
en6: flags=802<BROADCAST,SIMPLEX> mtu 1500
address: 00:1f:aa:ff:ff:d6
en7: flags=802<BROADCAST,SIMPLEX> mtu 1500
address: 00:1f:aa:ff:ff:d7
en8: flags=802<BROADCAST,SIMPLEX> mtu 1500
address: 00:1f:aa:ff:ff:d8
en9: flags=802<BROADCAST,SIMPLEX> mtu 1500
address: 00:1f:aa:ff:ff:d9
en10: flags=802<BROADCAST,SIMPLEX> mtu 1500
address: 00:1f:aa:ff:ff:da
en11: flags=802<BROADCAST,SIMPLEX>...
08/21/2008 2:19 PM
post12211
On Wed, Aug 20, 2008 at 11:23:55PM -0400, Santosh Kumar wrote:
> Hi Sean,
the interface.
I did a quick test here and it worked. Does 'ping -n ...'
behave any differently?
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
wm0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
capabilities tx=3f<IP4CSUM,TCP4CSUM,UDP4CSUM,TCP6CSUM,UDP6CSUM,TSO4>
enabled=0
address: 00:0e:0c:34:36:88
media: Ethernet autoselect (100baseTX)
status: active
vlan0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
vlan: 1234 parent: wm0
inet 11.0.0.2 netmask 0xff000000 broadcast 11.255.255.255
inet6 fe80::20e:cff:fe34:3688%vlan0 prefixlen 64 scopeid 0x3
seanb2:/home/seanb >ping -c1 11.1
PING 11.1 (11.0.0.1): 56 data bytes
64 bytes from 11.0.0.1: icmp_seq=0 ttl=255 time=0 ms
----11.1 PING Statistics----
1 packets transmitted, 1 packets received, 0% packet loss
round-trip min/avg/max = 0/0/0 ms variance = 0 ms^2
08/21/2008 3:33 PM
post12219
We did a change to one of our drivers (for a broadcom chip 5691) and that seemed to make a difference. Its working now.
Santosh
> > Hi Sean,
> -seanb
> enabled=0
> status: active
