Guenther Weiss
io-pkt crash on MPC8548 with two interfaces and prioritized RX path
Guenther Weiss
08/07/2008 9:04 AM
post11522
We use io-pkt (Milestone 3) with QNX 6.3.2 Kernel on a MPC8548 board with two network interfaces. We run one stack
instance for both interfaces because later a layer 2 bridge is needed (not operational for this testcase). On tsec1 we
want to receive and send UDP frames with low latency and do layer 2 bridging to and from tsec0. Especially the latency
should not be influenced by "normal" traffic on tsec0. Because the stack is single threaded internally, we use the BPF
(pcap library) to capture and send the UDP frames on tsec1. In our testcase a PC sends UDP frame and our MPC8548 board
(tsec1) loops it back with the attached test program. The PC sends the next UDP frame (128 bytes UDP data) immediately
after receipt of the response.
In this setup, io-pkt either terminates after a few frames with blown stack handling 0 or hangs with high CPU load (only
restricted by the Adaptive Partitioning). Increasing the stacksize didn't help.
The stack is started with the following options:
io-pkt-v4-hc -t4 -dmpc85xx mac=xxx,pci=0,phy=0 -ptcpip
mount -Tio-pkt -o mac=yyy,pci=1,phy=1,rx_delay=0,rx_frame=0, priority=185 /lib/dll/devnp-mpc85xx.so
ifconfig tsec0 up
ifconfig tsec1 192.168.44.2 up
I have made the following observations:
1.) It works, if the -t4 option is omitted. But then the interrupt received thread is running on default priority -> no
solution because of jitter
2.) It works, if only tsec1 is configured and used. It is not sufficient to have no network cable connected to a
configured tsec0 -> no solution - both interfaces are needed
3.) It works, if the UDP frames are received and sent via the socket interface (#define VIA_SOCKET in the test program)
and not over pcap_loop() and pcap_inject() -> no solution because of jitter when the single threaded stack is occupied
by traffic from tsec0
Am I doing something wrong or is this a bug in io-pkt, the pcap library or the network driver ?
Guenther
