libpcap: pcap_open_live with no read timeout (to_ms=0)
07/18/2008 9:00 AM
post10697
Hi all,
I'm experimenting with the pcap library and I open it in the following way:
pcap_open_live("tsec0", 1500, 1, 0, ebuf);
i.e. I'm using a zero read timeout for the BPF device.
The filter is setup to capture small amounts of packets every few seconds.
Later on I use pcap_loop() to receive packets.
My expectation from reading various man pages about libpcap was to be immediately be notified of any arriving packet
when using this zero timeout live capture setup.
However, it seems to me that I am getting notified of a whole bunch of frames at once , as soon as ~1500 bytes (the
snaplen) of frames have arrived (considerable delay w.r.t. to the arrival of the first frame).
Is the latter how it's supposed to be behave on QNX ? If so, is there any way to be immediately notified ?
BTW, the source file ./dist2/libpcap/pcap-bpf.c::pcap_open_live() line ~900++ contains a comment about this kind of
behaviour on AIX and different variants of BSD.
Thanks for any help.
Christopher
Re: libpcap: pcap_open_live with no read timeout (to_ms=0)
07/18/2008 9:23 AM
post10702
On Fri, Jul 18, 2008 at 09:00:32AM -0400, Christopher Pohl wrote:
> Hi all,
Can you post a small test case? We should follow the NetBSD behaviour.
07/18/2008 9:37 AM
post10704
> -seanb
I'll try to create one. At the moment my incoming (captured) traffic is generated by an external machine, so i have to
fake that somehow to make the test case any useful. I'm going to post it here then.
I noticed the following in the mean time, maybe the information is useful for you:
When I do
one = 1;
ioctl(*((int*)(ctx.pcaph)), BIOCIMMEDIATE, &one);
(the cast evalutes to pcap's internal /dev/bpf file descriptor) then this causes frames to show up immediately in my
packet handler one by one without delay.
Christopher.
07/18/2008 9:40 AM
post10707
> > -seanb
> When I do
> one = 1;
> Christopher.
Don't worry about actually generating traffic. I can do that here.
07/25/2008 3:49 PM
post11105
> Hi all,
> Christopher
I did some experimenting here and we do seem to follow the
NetBSD behaviour. If the timeout is 0 it means to block
until "some" packets have built up. This is doc'd in
trunk/dist2/libpcap/pcap.3.
07/29/2009 4:16 PM
post34856
I have the same problem, were you be able to solve the problem.
Mohammad
07/29/2009 4:20 PM
post34857
This wasn't a bug. timeout of 0 means wait until
the buffer is full.
07/30/2009 4:09 AM
post34876
As Sean said, this is how NetBSD behaves.
The following may help you:
#ifdef BIOCIMMEDIATE
* When libpcap uses BPF we must enable "immediate mode" to
* receive frames right away; otherwise the system may
* buffer them for us.
unsigned int on = 1;
if (ioctl(pcap_fileno(l2->pcap), BIOCIMMEDIATE, &on) < 0) {
fprintf(stderr, "%s: cannot enable immediate mode on interface %s: %s\n",
__func__, l2->ifname, strerror(errno));
/* XXX should we fail? */
#endif /* BIOCIMMEDIATE */
(stolen from WPA supplicant's sources: http://hostap.epitest.fi/wpa_supplicant/ )
Christopher.
