Sean Boudreau
09/04/2009 12:12 PM
post37391
Shot in the dark...
Do you have /etc/services ?
On Fri, Sep 04, 2009 at 11:56:21AM -0400, Todd Peterson wrote:
> I issue the following commands after the network is up under QNX6.3.2:
> export TZ=MST7MDT
> ntpdate ntp
> ntpd -g
> All works fine.
> Under QNX6.4.1 I get the following behavior:
> # export TZ=MST7MDT
> # ntpdate ntp
> Error : servname not supported for ai_socktype
> 31 Dec 17:30:11 ntpdate[274445]: can't find host ntp
> 31 Dec 17:30:11 ntpdate[274445]: no servers can be used, exiting
> Process 274445 (ntpdate) exited status=1.
> ntp is in my /etc/hosts file and I can ping & nslookup ntp:
> # ping ntp
> PING ntp.mgtsciences.com (172.23.93.7): 56 data bytes
> 64 bytes from 172.23.93.7: icmp_seq=0 ttl=64 time=9 ms
> 64 bytes from 172.23.93.7: icmp_seq=1 ttl=64 time=4 ms
> 64 bytes from 172.23.93.7: icmp_seq=2 ttl=64 time=3 ms
> 64 bytes from 172.23.93.7: icmp_seq=3 ttl=64 time=5 ms
> 64 bytes from 172.23.93.7: icmp_seq=4 ttl=64 time=4 ms
> ----ntp.mgtsciences.com PING Statistics----
> 5 packets transmitted, 5 packets received, 0% packet loss
> round-trip min/avg/max = 3/5/9 ms variance = 5 ms^2
> Process 290829 (ping) exited status=0.
> # nslookup ntp
> Server: 172.23.93.3
> Address: 172.23.93.3#53
> Address: 172.23.93.7
> Process 299021 (nslookup) exited status=0.
> sloginfo did not produce anything other than a line:
> Dec 31 17:00:26 3 25 0 Couldn't initialize listen service: tcp (Address already in use)
> Any suggestions?
> io-net migration
> http://community.qnx.com/sf/go/post37384
