Forum Topic - QNX 6.4 using old QNX 6.3 CAN drivers: (3 Items)
I'm using some old drivers for a CAN card that used io-net. They start up fine in QNX 6.4 and seem to share the same io-
pkt instance as the Ethernet drivers.
Everything generally works OK, but we are seeing some odd latency in receiving packets from the CAN card. When we have
some decent network traffic going into/out of the network, CAN packets come in at their desired rates. When the network
traffic stops, the CAN packets only come in every 200-500ms or so.
Could this be related to forcing io-pkt into single threaded mode due to it loading older drivers? If so, is there a way
 to force these drivers to use different instances of io-pkt? I tried the mount command but that returned errors about
missing symbols.
RE: QNX 6.4 using old QNX 6.3 CAN drivers
Is this on exactly the same hardware, as 6.3?
Because it sounds like you're somehow missing
or dropping interrupts.
The io-net driver, when run with the shim under
io-pkt, does exactly the same hardware accessing
as it does under io-net - it's the same binary
after all.
Is the interrupt shared?  That causes weirdness.
Is there any very high priority processing that
is occuring?
I would probably use the instrumented kernel to
try to get some more information about what's
actually happening - if the interrupt is firing,
and io-pkt is ignoring it - you will see it.
aboyd
From: Dan Tascione [mailto:community-noreply@qnx.com]
Sent: Monday, January 19, 2009 3:46 PM
To: ionetmig-networking
Subject: QNX 6.4 using old QNX 6.3 CAN drivers
up fine in QNX 6.4 and seem to share the same io-pkt instance as the
Ethernet drivers.
receiving packets from the CAN card. When we have some decent network
desired rates. When the network traffic stops, the CAN packets only come
it loading older drivers? If so, is there a way to force these drivers
returned errors about missing symbols.
io-net migration
http://community.qnx.com/sf/go/post20350
Re: RE: QNX 6.4 using old QNX 6.3 CAN drivers
I'll double check to make sure they aren't sharing any interrupts. The CAN driver is running at a higher priority than
the network driver, if that makes a difference.
Thanks, I'll go dig a bit more.
