Forum Topic - Xilinx devn-xemac not fully functioning with shim layer: (3 Items)
Hi all,
I'm trying to use the devn-xemac driver with io-pkt, using the shim.  This driver is present in the Xilinx Virtex II-Pro
 BSP, and is basically a thin QNX layer around Xilinx's EDK-provided source function.
No problems in 6.3.2.
Here's what's happening in 6.4 (using io-pkt-v4).
# io-pkt -ptcpip
# mount -T io-net -o mac=00112233445566 devn-xemac.so
# ifconfig
en0: flags=80008802<BROADCAST,SIMPLEX,MULTICAST,SHIM> mtu 1500
        address: 00:00:00:00:00:00
# ifconfig en0 192.168.230.100
# ifconfig
en0: flags=80008843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST,SHIM> mtu 1500
        inet 192.168.230.100 netmask 0xffffff00 broadcast 192.168.230.255
Now, when I try to ping another host, I see outgoing ARP packets, I see the response from the target host... but it
looks like the packets aren't being processed by io-pkt properly.  nicinfo report bytes transmitted just fine, but
nothing recieved.
Another issue appears to be that the shim layer isn't picking up the mac address, as it comes in at the default.
I suspect the problem is in the xemac driver not quite agreeing with the shim -- any suggestions on where to look?
Re: Xilinx devn-xemac not fully functioning with shim layer
This belong better in the drivers folder, sorry for putting it here.
RE: Xilinx devn-xemac not fully functioning with shim layer
Hi Alex:
	This certainly looks like a MAC problem of some sort.  All 0's
for the MAC is a bad thing...
I think that your MAC is incorrectly specified on the command line.  It
should be 001122334455.  While I don't think that this is the cause of
the problem, let's start there and see if it makes any difference.  You
can also try:
io-pkt-v4 -dxemac.so verbose
To start up the stack with the driver in verbose mode and then you can
post the output from sloginfo (assuming that you have slogger running)
and that might give us a bit more info.
	Robert.
From: Alex Pavloff [mailto:community-noreply@qnx.com]
Sent: Friday, November 21, 2008 2:53 PM
To: ionetmig-networking
Subject: Xilinx devn-xemac not fully functioning with shim layer
Hi all,
This driver is present in the Xilinx Virtex II-Pro BSP, and is basically
# io-pkt -ptcpip
# mount -T io-net -o mac=00112233445566 devn-xemac.so # ifconfig
# ifconfig
1500
192.168.230.255
the response from the target host... but it looks like the packets
transmitted just fine, but nothing recieved.
io-net migration
http://community.qnx.com/sf/go/post17093
