Forum Topic - Setting promiscuous mode on i82544 driver: (4 Items)
looking at ifconfig and the i82544 mount options or in the forums I couldn't find how to enable promiscuous mode on the
i82544 driver. How is it supposed to be done with io-pkt?  With io-net there was a mount option called promiscuous to do
 it.
Peter Engstrom
RE: Setting promiscuous mode on i82544 driver
Looking at the source, the stack makes an ioctl
into the driver which results in i82544_filter()
being called, which puts the hardware in promiscuous
mode if the stack has set the IFF_PROMISC bit in
ifp->if_flags
aboyd
From: Peter Engstrom [mailto:community-noreply@qnx.com]
Sent: Monday, October 20, 2008 3:25 AM
To: ionetmig-networking
Subject: Setting promiscuous mode on i82544 driver
couldn't find how to enable promiscuous mode on the i82544 driver. How
option called promiscuous to do it.
Peter Engstrom
io-net migration
http://community.qnx.com/sf/go/post15217
Re: RE: Setting promiscuous mode on i82544 driver
> ifp->if_flags
yes I have seen that code as well but how do you set the IFF_PROMISC bit? Using ifconfig?
Peter Engstrom
On Mon, Oct 20, 2008 at 12:30:48PM -0400, Peter Engstrom wrote:
> > ifp->if_flags
You can't.  IFF_PROMISC is part of IFF_CANTCHANGE.  There's
certain userland actions that poke the stack into
ifpromisc(): using the bpf BIOCPROMISC ioctl, creating a
bridge...
IIRC you've created your own lsm.  You'll probably have to
poke your lsm into calling ifpromisc().
