Yuri Shchors(deleted)
very slow libsocket/io-pkt interface
03/26/2009 7:49 AM
post25305
running io-pkt on mpc8360, which uses devn-ucc_ec + devnp-shim driver to
send the data through 1Gbit interface.
I have two tests to measure throughput of the interface:
1. Use raw sockets to send one prepared IP packet (1496 bytes) in a loop
2. Use bpf interface to send one prepared ethernet frame (1506 bytes) in a loop
Both tests yield throughput of about 14Mb/s, sending larger IP packets (32k) yield speed
of about 40Mb/s.
On the other hand, writing a lsm module for io-pkt which sends prepared ethernet frame
from inside io-pkt yields maximum throughput (120Mb/s).
Why is there so huge difference between the two approaches? lsm inside io-pkt also uses shim layer,
so I have to blame slow message passing between libsocket and io-pkt manager.
Andrew Boyd(deleted)
RE: very slow libsocket/io-pkt interface
03/26/2009 8:22 AM
post25309
Not sure about devn-ucc_ec, but on x86,
Robert was able to get wire rate on gige
with devnp-i82544.so and ttcp using only
14% of the CPU at larger sizes.
The message passing of QNX only affected
the slope of the asymptotic curve.
aboyd
Re: RE: very slow libsocket/io-pkt interface
03/26/2009 9:10 AM
post25314
> aboyd
Core 2 Duo, 2Ghz is not a payer here :-). I have single core, 533Mhz PPC.
It seems that either context switching or message passing is to be blamed.
Otherwise I can't explain the difference. I have no other running processes,
except of the sending one.
Yura.
RE: RE: very slow libsocket/io-pkt interface
03/26/2009 9:30 AM
post25321
> 533Mhz PPC
Not a problem. First gige driver I ever got wire
rate (well, 960 mbits/sec) was mpc85xx on PPC.
> to be blamed
No. Despite them being convenient whipping boys,
they only come into play for small packets. For
large transfers, the overhead is amortized.
I am not familiar with the ucc_ec driver - are
there any hardware limitations eg bus bandwidth?
As an example, generic PCI is NOT capable of wire
rate gige - you need PCI express for that.
Also, there may be driver limitations - a common
hack is always defrag before tx, which is not good.
Just because a driver will ping, does not mean that
it is capable of doing wire rate gige with low cpu
utilization. It took a lot of work by Robert and
me and Sean (enabling TSO, hardware checksumming,
interrupt throttling, etc) to get wire rate on x86
with ttcp and 14% cpu with devnp-i82544.so
Another whipping boy: don't always blame the shim.
We did a test with 100mbit pcnet, and we got exactly
the same throughput with a shim pcnet driver, and
a native pcnet driver.
Hugh recently ported the devn-e1000 driver to io-pkt,
and he was disappointed to learn that the devnp-e1000
driver only reduced the CPU utilization by ONE PERCENT
during his benchmark testing.
Despite what many people think, creating a reliable,
fast, efficient, maintainable driver is not always a
trivial task.
aboyd www.pittspecials.com/movies/tumble.wmv
Re: RE: RE: very slow libsocket/io-pkt interface
03/26/2009 10:21 AM
post25342
Well, there have to be a problem somewhere...
The difference is quite measurable.
the memory bus is 32 bit x 133 Mhz DDR, which gives
us 4*133*2 = 1064 Mbytes/second, which is x8 the ethernet rate.
This is neither driver nor shim limitation,
since both io-pkt lsm and libsocket use it.
> utilization.
I'm capturing all the packets correctly on the client side
with wireshark. Also, I don't care about low CPU utilization,
pushing the data through ethernet is my main concern.
Noting that mpc8360 has two gigabit interfaces, I must
conclude that it's powerful enough to fill both of them.
Thanks for the fast reply,
Yura.
Robert Craig
RE: RE: RE: very slow libsocket/io-pkt interface
Robert Craig
03/26/2009 10:31 AM
post25345
I'll just comment quickly on the CPU being capable of filling two
gigabit-ethernet ports and say "don't count on it". I seem to remember
having real problems with the 8313 (which is a similar chip) Ethernet
FIFOs being capable of filling the GigE pipe (I'd get FIFO underruns /
overruns especially when using jumbo packets). This may have only been
a problem with the particular chip that I had at the time, but who
knows? In terms of raw CPU, the actual limiting factor is
packets-per-second, so it's unlikely that you'll be able to fill a
single pipe with 64 byte packets, but you may be able to fill both pipes
if you use jumbo packets.
R.
From: Yuri Shchors [mailto:community-noreply@qnx.com]
Sent: Thursday, March 26, 2009 10:21 AM
To: general-networking
Subject: Re: RE: RE: very slow libsocket/io-pkt interface
> No. Despite them being convenient whipping boys, they only come into
> play for small packets. For large transfers, the overhead is
> amortized.
> I am not familiar with the ucc_ec driver - are there any hardware
the memory bus is 32 bit x 133 Mhz DDR, which gives us 4*133*2 = 1064
> Also, there may be driver limitations - a common hack is always defrag
This is neither driver nor shim limitation, since both io-pkt lsm and
libsocket use it.
> Just because a driver will ping, does not mean that it is capable of
> doing wire rate gige with low cpu utilization.
I'm capturing all the packets correctly on the client side with
wireshark. Also, I don't care about low CPU utilization, pushing the
Noting that mpc8360 has two gigabit interfaces, I must conclude that
Yura.
General
http://community.qnx.com/sf/go/post25342
03/26/2009 10:40 AM
post25350
IIRC it used the low-rent tsec which had MUCH
less DMA bandwidth available than the etsec
implementations, which worked MUCH better at
gige.
Gotta have both bus bandwidth, and low latency
(re fifo underruns/overruns).
aboyd
Robert Craig
Robert Craig
03/26/2009 10:18 AM
post25340
Hmmm... Interesting one...
So BPF / Raw socket produces ~ 1/3 of the rate of the direct interface
through an LSM.
By hooking into the LSM layer, you're likely also bypassing quite a bit
of stack / message processing in addition to removing the message pass
/ data copy associated with an external application.
Just to check, are you sure that you're CPU limited in both cases (very
likely so, but it doesn't hurt to ask).
If you're looking to an external interface for generating raw packets,
you might also want to have a look at lsm-nraw.so. This will bypass the
stack processing but leave the message passing interface in place.
Just to check... Are your measurements Mega Bits per second or Mega
Bytes per second? I'm assuming megabytes since 14 megabits seems
extremely slow.
If you're really interested in solid numbers you can always get a kernel
trace to see what's happening. You sometimes see "unexpected"
interactions when you look at the kernel trace.
R.
Sent: Thursday, March 26, 2009 7:50 AM
Subject: very slow libsocket/io-pkt interface
a loop
(32k) yield speed of about 40Mb/s.
ethernet frame from inside io-pkt yields maximum throughput (120Mb/s).
io-pkt also uses shim layer, so I have to blame slow message passing
General
http://community.qnx.com/sf/go/post25305
03/26/2009 11:28 AM
post25360
> through an LSM.
Yes.
using nraw will give me about 18 Megabytes/sec on priority 10
and about 28MiB/s on priority 100.
I've looked at the kernel trace, and don't see some unusual interactions there.
I've attached the trace, in case you'll want to have a look at it...
Yura.
03/31/2009 5:01 AM
post25626
I've looked at the kernel profiling info for both io-pkt module and lsm-nraw usage.
in first scenario I'm able to send 12Mb/sec using 20% of CPU, in second one almost the
same amout of data (14Mb/sec) takes 100% of CPU. When using nraw interface, for
each 2msec inside io-pkt there's 1msec inside procnto-600. 1msec is about 500,000 cycles.
Wasting that much time inside the procnto could be explained by running from uncacheable
memory or flash. But the entire ifs image is copied to DDR before running, and I suppose that one of the things procnto
does is to enable the dcache. Copy entire ethernet packet (1500 bytes) takes
between 1200 to 200 cycles, which makes me wonder where the rest 490k cycles are spent.
Yura.
03/31/2009 9:30 AM
post25639
> for each 2msec inside io-pkt there's 1msec inside
> procnto-600.
Shot in the dark: the CACHE_FLUSH() during tx.
As a test, try commenting it out (yes, the packets
transmitted will be corrupted) and see if that changes
things.
Also, another thing that really kills benchmarks is
io-pkt allocating pages, which requires sending messages
to proc. Make sure that during your test, when you do a
"pidin mem", that io-pkt is NOT growing it's data. Before
the benchmark begins, you want to make sure it's steady-state -
it's allocated all the clusters it's going to need.
aboyd
Robert Craig
Robert Craig
03/31/2009 10:13 AM
post25650
What thread is being executed in procnto? Is it the idle thread?
R.
Sent: Tuesday, March 31, 2009 5:02 AM
Subject: Re: RE: very slow libsocket/io-pkt interface
lsm-nraw usage.
one almost the same amout of data (14Mb/sec) takes 100% of CPU. When
using nraw interface, for each 2msec inside io-pkt there's 1msec inside
from uncacheable memory or flash. But the entire ifs image is copied to
DDR before running, and I suppose that one of the things procnto does is
cycles are spent.
Yura.
General
http://community.qnx.com/sf/go/post25626
03/31/2009 10:50 AM
post25666
> R.
Oh, no... it's not
Yura.
03/31/2009 10:52 AM
post25668
What does the instrumented kernel show
for kernel calls, interrupts, etc? It
can be really helpful for this kind of
system diagnosis.
aboyd
Robert Craig
Robert Craig
03/31/2009 10:52 AM
post25669
I'm surprised that procnto is involved at all. Hmmm... From the trace
can you see what causes the kernel thread to run?
Sent: Tuesday, March 31, 2009 10:51 AM
> R.
Oh, no... it's not
Yura.
General
http://community.qnx.com/sf/go/post25666
06/24/2009 1:15 PM
post32471
> a loop
Just to complete the picture: I've found that memory throughput to the PPC core (but not to the DMA) is about 100Mb/s
(one way!), so my theory about having 32 bit x 133 Mhz DDR2 = 1064Mb/s memory throughput doesn't reflect the real state
of affairs :-). Copy data twice by the CPU and you have 50Mb/s throughput, which I almost achieve using large UDP
packets. I've tried to play with various bus arbiter registers but had no any improvement. I guess, I'll have a FPGA to
prepare network packets for this ,umm, network chip, and then use io-pkt module to send them without copying to the
network.
